Thanks for the reminder. Totally forgotten about this. Haha. [quote=AdrianM] Any updates? Thank-you. [/quote]
interested if the price is nice:)
Any news on this yet Freeme?
Have they tested the OSRAM CSLNM1.TG in this light to assure they have selected a reflector that can properly focus the beam for maximum throw? I think its important to ask, given the way they botched up their SBT90.2 version of this same light. Maybe you can have them send a sample out to one of BLF’s rigorous capable reviewers for a pre-production shake-down to avoid dozens of flashlight returns that could have been avoided.
Thanks!
How many more are interested? NM1 and PM1?
I’m interested for sure if the price fits
Price shouldn't be too far away from XHP50.2 version.
i am in
Is there an update on this coming soon?
I’d be happy to do it myself if there was a centering ring available. That, plus a x% FET build of Anduril (based on battery current).
Interested in the 2mm Osram and hopefully the Boost HX. But interest depends on how good the driver is because the Noctigon K1 already has a quality regulated driver. Hopefully send the light to someone that can test this light properly before selling. I got a refund for the SBT90.2 version because of how Astrolux messed up so many things on that version.
Interested
Interessado
Well this depends on the driver. The 2mm size LED you can direct drive so the stock driver will be fine but the smaller 1mm LED needs to be amperage limited. Do they have a driver in mind? I think you can get these LEDs in 5000k tint also.
Interested
I suspect they are having the same problems with the reflector improperly focusing the beam pattern as they have with the SBT90.2 version.
You’d figure this would’ve been well tested at the prototype stage, unless this is something to do with manufacturing tolerances. Ironically enough, I see an add for Astrolux FT03S at the top of the screen… with SBT90.2. :person_facepalming: Problem hasn’t been addressed with fixed stock available to ship yet, right?
FT03 with Osram LED, interested. But hopefully the reflector size/depth are tested properly to get max candela (in other wods, properly focused to get the most out of it).
Interested
Interested
Did they force you to ship it back to them in China at your own expense?
