[short review] Niteye/Jetbeam Jet-II Pro 12th Anniversary edition
25 posts / 0 new
Unheard
Unheard's picture
Last seen: 23 min 49 sec ago
I bought the Jet-II from BG with a code nicely provided by M4D M4X. The light arrived without battery. Not Jetbeams fault I suppose since the package has been opened. I understand BG refuses to ship batteries to certain countries, but they should state that they will do so. I filed a complaint and will not buy again from BG until it is resolved in a way that I somehow will receive a free battery.
N.B.: Images show a light with a custom LED. The Jet-II comes with a CW XP-L Hi.
First impressions:
Not having the battery was disapointing, much worser and a real annoyance is the the clip not seated tight between tube and tailcap.
OTOH, the clip is only needed to help finding the side switch. The “attack head” will in either position ruin you clothes. The bezel is full of sharp edges. Taking it off improves things, but the thread still has a keen edge.
Edit:
I was missing an important detail: Below the clip there’s actually a replacement bezel that can be taken off! It doesn’t help the clip problem, but does not make it worser at least.
After inserting my battery, the flashlingt came to life not before trying double click for moon (sic). It seems that when the battery was removed some time ago, the flashlight starts in lockout mode. Amazing. So, preesing the side switch for five seconds or so brings it to life.
Next, going from mid to low and from low to high goes with a noticable flicker.
Material and construction:
Body, head, bezel, tailcap, replacement bezel: Titanium alloy
Clip: Likely stainless steel
MCPCB on shelf, driver with piggyback pcb for the button. Plus contact is a button, tailcap contact is a spring
Four tritium slots in the tailcap.
UI:
Double click for moon, then hold to switch between moon and high.
Single press for on, hold to switch H-M-L, H on double click.
Long press for lockout (moon/high still available) on double click.
Strobe on triple click.
Beam:
Moon is dark enough. Could be less, but can be used to preserve night vision.
The OPR is the true highlight.
I’ve never had a flashlight with such a great reflector. Texturing is very nice, producing a soft spot without artifacts even after implanting a LED with a dome (the original XP-L Hi is domeless). Of course, the LED is in focus.
The beam ist the second best (after tearing trousers) argument for not using the bezel.
Heat:
Lots of. Only 500 something lumes, but you cannot hold the light after less than a minute. Since head and battery tunbe aren’t seperated, the heat will distribute over the whole light.
Appearance:
The engravings are nicely done. They read “12 Years”, “Classic” and “Jet-II Pro personal defense”. There are some ornaments. Nice. The sideswitch carries the Niteye logo.
Someone said, this light would look like a chess piece. True, it could be the king, but never the king of industrial design. There’s not much beauty. Clip is likewise ugly, but at least not sharp.
Technical Data:
Nobody cares, I suppose. This is really only a collectors item. You cannot use it because the sharp thread is covered by a sharp bezel. Yeah, of course to can take it out of the showcase, make light, then shelve it back.
Modding:
No glue, do what you want. I did an emitter swap, I have in mind…
(1) to shorten the battery tube thread to have the tailcap pinching the clip
(2) cutting off the jags of that … bezel
Smile, you cannot kill them all.
Edited by: Unheard on 05/12/2020 - 11:58
ahirshy
Last seen: 5 months 5 days ago
How wide is the Jet-II head? Is it possible threads are similar to any other standalone bezels available separately...
Is it an 18350 tube or 16340 only? If 18mm, possibility the slightly wider head ring might be able to use Lumintop's Stainless Bezel (made for FW3A/FW1A)
Not sure if this Bezel would lego with this Jetbeam - I'm also interested in it for an Astrolux or BLF A6/S2+. (Posted on a different thread)
FW3A - SS Bezel head ringFW3A - SS Bezel individual
Maybe worth a few quid to buy a few bezels and experiment. Got the same Ti Jet-II flashlight on the way (also thanks to M4DM4X groupbuy), so will likely find myself in a similar conundrum soon!
Unheard
Unheard's picture
Must not exceed few millimeters, else it becomes an aperture for the spill. Threads are a problem. D4V2 bezel doesn’t fit D4, early Sp32V2 don’t lego with later ones and so on.
I wonder if Jet2 Pro bezels fit. Those lights come with an extra bezel.
Keron
Keron's picture
Last seen: 4 weeks 1 day ago
judging by your pictures the machining looks identical to my jet ii pro titanium, even the tailcaps are the same exact design with just different finishing im, very certain the bezels will fit yours just perfectly
the clip isnt an issue… you just have to find the tiny little indentation around its diameter and line up perfectly with the clip’s ring protrusion in order to fully tighten down its tailcap
You’re not wining, you’re surviving.
Unheard
Unheard's picture
The tailcap is fully tighten down in that image. That’s the problem.
Keron
Keron's picture
would you mind taking off the clip and take a picture of it?
Unheard
Unheard's picture
Keron
Keron's picture
please check around its diameter carefully if you dont mind, there really should be a indentation like on mine circled in red on the right which you suppose to line up perfectly with the clip’s pointy area on the left
if not, that is one hell of a serious manufacturer defect jetbeam had just manage to fuck up…
Unheard
Unheard's picture
Believe me, there is none. Even if there were a notch, it wouldn’t work as there’s 1.5mm space between tailcap and tube. I can rotate the clip around.
I wonder what ahershy’s findings will be.
Keron
Keron's picture
sorry to hear that, but i am too disappointed with jetbeam’s hit-or-miss quality control
think the last bit you could save it is by cutting or filing down the protrusion on the clip until its flat to work along the ring diameter
Unheard
Unheard's picture
Why? The clip can only be in a fixed position if is sits tight between tailcap and tube. Therefore the tube has to be filed down by about 1.2mm. I need to find someone being able to do this without ruining the thread. I think I cannot do it myself.
Edit: Oh, next problem would probably be space. Maybe the battery won’t fit anymore after shortening the tube Tired . A washer maybe?
ahirshy
So now all we need to do is find someone with a spare Bezel that came with their Pro who is willing to sell or give away! If I remember correctly the Jet II Pro editions all had round buttons. Except the limited copper version which was styled exactly like this Anniversary edition with square button. That particular one also didn’t some with a replacement smooth bezel!
Do Jetbeam have these components available to purchase separately, or a contact to purchase spares?
I will definitely let you know once it is received. Got a spate of lights coming (something to keep busy during lockdown); this particular one was an impulse purchase, very usually for me, made on the very last day of Martin’s groupbuy that I didn’t want to miss out on the deal. So hope it works out.
Unheard
Unheard's picture
I wrote them a letter (info@jetbeamlight.com). Will let you know if I get an answer.
The more I’m toying with this light, the more I wish I can fix the various flaws. The beam is incredibly nice.
There are four shafts below the head. They look like they’re there for taking trit vials, but I don’t know of any short, fat vials. Must be 3×6mm or so. Any sources?
Keron
Keron's picture
15×6mm actually, at least on mine and it has space for 4 of them, the middle section is blocked off not allowing a 3×6mm vial to go through
i ordered from here, that is if you dont mind long waiting time
https://www.aliexpress.com/item/33042028115.html?spm=a2g0s.9042311.0.0.1...
Unheard
Unheard's picture
Yes, the tailcap slots appear to take 1.5mm. I meant the large slots up where the switch is. But thanks for the link Thumbs Up
Unheard
Unheard's picture
Look carefully: From where have I taken this bezel? Facepalm
Keron
Keron's picture
no idea
Unheard
Unheard's picture
There’s a replacement bezel below the clip. I’ve edited the OP. That explains why there’s no notch for the clip.
I’ve asked Jetbeam if this part can be ordered seperately.
NotSoBright
Last seen: 23 hours 59 min ago
Are you sure it’s a replacement bezel?
Try this, put your “replacement bezel” back where it was, tighten it all the way down towards the head. Replace clip and tail cap.
Is there a gap?
Unscrew “bezel” away from the head and towards the tail, until gap is gone.
Gap problem solved. But we still gotta do something about that horrid piece on the front.
Unheard
Unheard's picture
Yes. It is shown in the manual. I did just not understand it.
Is there a gap?
Yes, I’ve already shown pictures showing that gap.
Yes, tried this and it works quite well.
Order another one of those rings. They are $2 or so. What hurts is shipping Facepalm Tired .
The_Flashaholic
The_Flashaholic's picture
Last seen: 20 hours 53 min ago
Wasn’t there a 12 year anniversary JETBeam light doing the rounds 3 years ago?
My 4K Lumen Whore Reviews (MS18, X70, MS12, DX80, X80-GT, X45vn etc) - http://www.youtube.com/c/FLASHAHOLIC_TV
Firelight2
Firelight2's picture
Last seen: 35 min 41 sec ago
One other observation:
The crenelated bezel is reversible. Don’t want the crenelations? … just reverse the bezel. Or install the alternate smooth bezel from the box.
The_Flashaholic
The crenelated bezel will scratch the hell out of the knurling if reversed, just tried it, had to back off.
Firelight2
Interesting.
I don’t have this 12th anniversary edition by I do have the Titanium Jet II Pro from 2 years ago, which the anniversary edition is based on.
The Jet II Pro seems to be a little better engineered.
  • The crenelated bezel does not touch the head even in the reverse position. It’s very close … a fraction of a milimeter, but doesn’t actually touch so there is no grinding.
  • Comes with the completely smooth alternate bezel in the box
  • Rear body tube has 3 notches allowing you to choose the position the clip locks into. Quite a nice system for locking the clip actually… much better than the simple o-ring used in the FW3A.
Unheard
Unheard's picture
And finally – the demilitarized, clip-fixed, light-beautyfied version of the Jet-II Pro Anni:
I’m sure it is, but the reversed “defense-bezel” doen’t touch the body on my light also. And the replacement bezel is part of the light. But yes, another ring should be part of the package to have the clip pinched.
For what M4DM4X offered it plus cost of a replacement bezel it is still inexpensive.
Edit: BTW, this unconventional ring determines the position of the tailcap. E.g., you can align the trit slots perfectly. Just use loctide to fix the height of the ring.
