I did a full test two of them on an Opus BTC3100 and got 3055 and 3012 mAh. I tested the other two on a Liitokala LH-500 and got 3122 and 3040 mAh. So they seem to have decent capacity, though I have no idea how they would go under heavy drain. I intend to use them in some flashlights. They weigh about 46 or 47 gramms on my kitchen scales.
So what is your opinion, are they fake or genuine?
I’m surprised they tested that high for capacity, for two reasons:
Most automated testers stop the test above the 2.5v that many manufacturers use when rating capacity, so they don’t squeeze out the last ~100mAh
Most automated testers don’t use the super-low current that manufacturers use when rating capacity (lower discharge rates results in higher capacity)
Visibly, they don’t look obviously fake.
The real way to tell is to load test or test impedance / internal resistance.
For fun once I bought some 25R and 30Q cells off Amazon - I was 99% sure they would be fake, but knew that Amazon would refund me if (when) they were. They had the right capacity (somewhat surprisingly), but failed spectacularly trying to output anything over like 3A.
On fake FLAT tops, I noticed the 3 in “30Q” is different from the genuine. On the fakes the both the top and bottom of the 3 is rounded. The 3 on yours looks like genuine, with the top of the 3 being “slashed”. My fakes were from Amazon maybe 2 years ago. They were also about 2400 mAh capacity instead of 3000.
While IMR has a nice selection and good pricing on some cells, be VERY careful on some of their protected cells! They are currently selling a Sanyo NCR18650GA that is capable of 10A continuous output, BUT it has a third-party protection circuit added that is only capable of 5A continuous. They don’t mention that 5A limit anywhere which seems very misleading to me.
You got 10 of what? You posted right after mine so I thought you were talking about the protected Sanyos, but now I see you said the 18650 Battery Store and not IMR Batteries.
I tried in the liitokala, but it was showing very inconsistent results. Of course I should have googled how to do this before I asked. So as I gather, you get a large resistor like 10ohm, do a quick voltage measurement with no load, then again quickly with load (like for a second or two), plug the values into a formula and you get the resistance. I wish the charger was more accurate and consistent.
Yes, many meters don’t give consistent readings. My Vapcell S4 Plus gives actually pretty steady results, but according to HKJ’s review the values are lower than reality. I have noticed that measured value does seem to change based on the charge level of the battery.
No worries, I just wasn’t sure I would recall it correctly and didn’t want to post something from memory.
The second character “0’ in the first line should be a dead giveaway that they are real. Granted I have 30Qs from Liion wholesale (which is a ”trusted” dealer) that DO NOT follow the Samsung datasheet and they swear up and down that they are real.
One thing that guy says is that every Q30 he’s seen uses 3 legs on the top contact. These appear to only have two legs, IE one on each side. Does that suggest anything?
Yours are sounding like fakes to me — unless others who recently purchased these cells from known reputable dealers have also seen this new difference.
That is ALL you need to know. Mooch has a lot of experience and in my 9 years of buying 30Q I have Never seen one with Two Legs.
There are photos on this forum of Two legs but I could not find them.
Hold on. Are all yours BT? They do not look that great, but what Two leafs are you talking about? I thought you were referencing that to the FT batteries?
No OEM cell manufacturer makes button top cells, all button tops are modified by someone. You would need to take that top layer of shrink and the button top to see. Most trusted retailers like Liionwholesale, illumn, and 18650batterystore add the button top, insulator, and a top layer of clear shrink ontop of a legitimate cell.
True, but I trust Mooch’s experience and his recommended retailers substantially more than I do your opinion.
Have any of you seen any fakes that try to replicate the markings on the cell wall under the wrapper for a 30Q? Seems like more hassle for the fakers to go through. Thoughts?
