Test/review of Hohm 18650 Life4 3015mAh (Black-white)
4 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 weeks 1 day ago
DSC_2464
Official specifications:
  • Capacity: 3015mAh
  • Max Charge Rate: 4.43A
  • Max Charge Voltage: 4.2V
  • Continuous Discharge Rate: 22.1A
  • Max 80oC | 3.2V cut-off: 31.5A
  • Pulse | Peak6: 37.1A
  • Cycle Life Retention: 500 70%, 1000 60%
  • Chemistry Type: QSP Li-NMC
Hohm%2018650%20Life4%203015mAh%20(Black-white)-info
This is a fairly high capacity and high current cell.
DSC_2457
DSC_2458
DSC_2459
DSC_2460
DSC_2461
DSC_2462 DSC_2463
DSC_2465 DSC_2466
DSC_2467
DSC_2468
DSC_2469
Hohm%2018650%20Life4%203015mAh%20(Black-white)-Capacity
Oops, the two batteries do not match in capacity, this means never use them in series. One of the cells is significantly below rated capacity.
Hohm%2018650%20Life4%203015mAh%20(Black-white)-Temp-15.0
Hohm%2018650%20Life4%203015mAh%20(Black-white)-Temp-20.0
Hohm%2018650%20Life4%203015mAh%20(Black-white)-Temp-30.0
Hohm%2018650%20Life4%203015mAh%20(Black-white)-CapacityTimeHours
Hohm%2018650%20Life4%203015mAh%20(Black-white)-Energy
Hohm%2018650%20Life4%203015mAh%20(Black-white)-PowerLoadTime
Hohm%2018650%20Life4%203015mAh%20(Black-white)-TripCurrent
Hohm%2018650%20Life4%203015mAh%20(Black-white)-Charge
Discharge-Hohm%2018650%20Life4%203015mAh%20%28Black-white%29-pulse-1.0%2010%2010-IR
Conclusion
I am not happy about the difference in capacity between the batteries and the very precise capacity rating do not really match the batteries.
Notes and links
The batteries was supplied by Hohmtech for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
shadockan
shadockan's picture
Thank you HKJ .
I have four batteries from this company.
I have two 18650 and two 21700.
The 21700 Hohm RUN 3023mAh are good batteries.
It’s not the same as the Samsung 30T, but it’s good.
The 18650 Hohm STRETCH 2856mAh …… they never worked ……….
The batteries had 0.20 and 0.11 Volts.
I tried to charge the batteries with the Turnigy Reactor 300W 20A and the MiBoxer C4-12.
The batteries were not charged.
The batteries were sent by the Hohmtech .
leftdisconnected
Last seen: 2 weeks 4 days ago
Thanks, HKJ!
I agree with your summary and wouldn’t buy these for myself. A quick check showed them priced higher at the time of this post than better Sony and Samsung cells. The inconsistency within such a small sample suggests poor manufacturing.
RobAllen
Superstocker
Superstocker's picture
Last seen: 1 day 4 hours ago
Thanks HKJ!
