I’m more confident in my soldering skills than my metalworking, so instead of a brass bar, I decided I would solder 5 small pogo pins together as a signaling contact. Cheap and effective, bought 100x pogo pins for $11-ish.
Made a S2+ shorty with a Nichia 219B 3000K LED (from azhu) and a Convoy V.2 driver. Added a 470 ohm bleeder resistor for the aqua (mix of green and blue 0805 SMD LEDs) lighted tailcap. The tailcap takes just 0.15 milliamps so lasts almost a year on the 18350 Keeppower 1200mAh battery.
Nothing too spectacular, but I was able to reflow a 4500k 219B into my Wuben E05 this weekend.
The only thing I had issues with was tapping the excess solder out. Once the MCPCB was hot enough I slid the old emitter off and tried to tin the pads just a little with some thin, rosin core 63/37.
Then I let the board and hot plate cool to ~75C(to slowly heat the emitter up), placed the emitter on the board and reheated to 220C.
Emitter centers itself, I tap it, solder balls pop out and I get some excess at the middle of each side of the emitter. Problem is that it sucks back under the emitter after a few seconds. Id imagine thats not great for thermals and consistent focus. What I ended up doing is placing a roll of tape next to the hot plate and placing a silicone backed ruler half on the roll of tape and the tip on the emitter to put gentle, even, centered pressure on it as it cooled. I cleaned the dome with some rubbing alcohol after but I didnt know if there was a better way to do this.
I was giving it a good solid thunk, but I wasnt quick or dexterous enough with the toothpick. The datasheet stated to not keep it at 200C for more than 2 minutes and up to 260C for 1 additional minute. I didnt want to damage the emitter so I was trying to be quick.
Overall, the beam is ever so slightly narrower, but the spill seems brighter and more usable. There are some minor beam artifacts in the hotspot, but nothing noticeable in real world use.
I’ve experienced the same issue as you when tapping the LED and having the solder creep right back under the LED. That seemed to happen when trying to remove the last bit of extra solder.
I now hold the LED down with a cotton swab and then swipe away at the extra solder with a toothpick. I split the toothpick to make the end smaller and flatter to help with the swiping.
Congrats on your reflow! And if you’re concerned about the extra solder, just heat it back up again to give it another shot (quickly).
Well not yesterday, but happened within the last week. I performed the following mods on my blue anodized Lumintop LM10:
O-ring switch mod. Exactly the same as for FW3A. Made even simpler since the bag of o-rings I got from Amazon for my FW3A probably contained 100 o-rings of the right size.
File anodizing off bottom of switch pill. The LM10’s tailcap contains a pill that screws in from the back. This pill holds everything in place and feels very secure. However, I noticed that with my blue anodized LM10, the light wasn’t as bright as my FW3A. I thought this might be because all the threads were also anodized where main current needs to pass through. A very light sanding to remove anodizing on the bottom of the switch pill seems to have fixed this issue.
The LM-10 is pretty nice. Feels much more solid than an FW3A. Note that my “blue” LM-10 is actually dark grey with the barest hint of blue tint. Looks nice, but not at all like the pictures.
Back in December I picked up a couple Utorch UT01’s from eas. He described them as “These are intact lights with the flakey UT01 driver. They’ve seen a bit of use. These are probably only useful to someone who likes to make tiny drivers.” Well, that was back in Dec 2019 and I made the drivers right away, but kept running into problems. I thought something was buggy with firmware, and I set it aside for 5 months.
Well, I just dusted them off yesterday and finally got it working. As it turns out, I had mis-wired the switch.
I used the top board from the stock driver, so I could assure proper placement of the switch and it keys into slots in the driver cavity to keep it from spinning. I crafted a new (li-ion only) driver using a linearly controlled FET via a QX7138, run by a attiny412 running RampingIOS (D4V2 UI). I should have thought ahead and used a attiny816 (now that I have Anduril running on the 1-Series) because Anduril is just too big for 4KB. I could use another FSM firmware though, like Baton which will fit easily. Now this is truly an e-switch 14500 light worth using!
PS - oddly enough, everyone seems to have blamed the original issue on the switch being flaky. The switch is the only original thing I’m using and it seems to work perfectly fine for me on drivers that were known to have the “switch” issue. Weird.
