So, is there a current, very popular 14500 light on the scene?
How about the Lumintop Tool AA? Is that light readily modded to a Nichia 219BT 3500k, for floody, warm output?
There used to be a 219C version of the Tool AA floating about. Sadly it seems to be gone. So I’m siding the SP10 crew.
I had forgotten about the Manker E11. In fact I have one, somewhere.
Can the Manker E11 readily accept an emitter swap to a Nichia 219?
Sadly, that’s what killed it for me. Everything else is great. Sure wish they’d put in a driver circuit capable of running Anduril.
I’m hoping that loneoceans next target for his lume1 driver is the skilhunt m series. (Prayers)
Yes. I swapped Nichia 219b and sanded 60° TIR lens to fit. The bezel is glued but it’s easy to remove with a strap wrench
The Nichia version of the Tool AA 2.0 isn’t gone. I recently bought one. They’re often on backorder, because they’re popular and not sold by every vendor that sells the other version.
nice :+1: ,
i have a sp10 2.0 that is begging for a 219b sw45k, will try sanding down an old TIR,
did you use the glass lens ?
The SP10s with the optional 2 way clip is a nice edc for sumer time :sunglasses:
The Reylight Copper Pineapple looks great.
Do you know if the emitter is readily accessible on his lights?
Thumbs UP!
remove the Cool White Low CRI LED
replace with Warm White High CRI!
with a Nichia, the CRI will go up,
a similar percentage as the max output will go down.
I think it is totally worth the trade off.
more quality
less quantity
Including Lumintop’s Ali store, right? Because it’s not available there. (And for me, American sellers are out of the question, shipping is far too expensive.)
EDIT: If the Tool AAA with Nichia is still around, I’d love to hear of it. I seldom take mine out of the house for fear of losing it, that’s how much I love it.
Tool AA 2.0 is with PWM right?
Yes, indeed. Happy to trade away some output for warm tint and higher CRI. That’s a trade I would make with nearly every light that I have. Only exceptions would be the dedicated throwers that I only use off my back porch out into the wilds.
I lost (temporarily) an EDC light that I loved once. EagleTac 25A Titanium. Since then, every light that I take with me out the door, in my pocket, has a lengthy lanyard clipped to it, and connected to my belt loop. Won’t ever lose a pocket light again.
sent you a PM with a link
maybe not anymore,
but, the lowest mode is 10 lumens and it has memory… neither works for me
glad you took control
did you lose a light that was clipped to a pocket, or all the way inside a pocket?
offtopic
imo the most revolutionary light that I would encourage you to discover, is the
Jetbeam RRT-01… nothing else comes close, for my personal EDC preferences
I will have to have a look at the RRT-01. Can it do warm, high CRI, flood? I’m about equally good with 14500, as 16340, even 18350. I just want fairly compact and rechargeable li-ion, not primaries.
The light I lost was clipped to the corner of my pocket. It was found by someone else, later, who realized that it was mine.
Now, with the lanyard, I drop the light into my pocket and never worry about losing it.
Would recommend looking for the old model rrt-01. The new one is very heavy and bulky, certainly compared to the eagletac.
Yeah… EagleTac created a masterpiece with the D25 line. I just wish you could get them with warm & high CRI emitters. Mods are possible on at least some of their lights, though.
I also have great appreciation for Olight’s S1A Baton with TIR optic - pop a 3000k XM-L2 under that TIR and the floody beam and warm color are magnificent! Great compact size, too.
I still carry and love my Utorch UT01. Somewhat programmable. Simple. Great battery life. Compact. And takes both AA and 14500.
The LED is easily accessible (2019 RRT01). I have not even had to disassemle the head completely to get to the MCPCB if memory serves. Not sure if there’s a TIR optics that would fit. The reflector geometry makes a more narrow spill. Best would probably be to stay with a domeless LED, else it might have some artifacts in the beam, but that’s just a guess based on my experiences with other deep smooth reflectors.
