dave1010
(dave1010)
May 12, 2020, 6:41pm
9
It’d be interesting to add a couple of bigger ones on here, to see how they compare per cubic centimetre (such as Imalent’s MS18 at 100,000 lumens).
Some other single 27100 lights, around 9000lm:
Nitecore TM9K
Imalent MS03
Nightwatch NS53A
The Astrolux EC03, Lumintop FW21 Pro and Fireflies E07 are all around 6000lm, so probably won’t make this list.
Could a single 18650 the size of a D4 drive 3 XHP50.2 LEDs over 10,000lm?
led4power
(led4power)
May 12, 2020, 7:18pm
10
You could also add lm/gram unit, but also unit which would tell how long those lumens can be sustained (for ex. before OTP kicks in, or brightness drops below 90% of initial max. lumen, whichever happens first), units could be lm*sec/cm3 , and lm*sec/gram.
richbuff
(richbuff)
May 13, 2020, 2:05am
11
dave1010:
It’d be interesting to add a couple of bigger ones on here, to see how they compare per cubic centimetre (such as Imalent’s MS18 at 100,000 lumens). Some other single 27100 lights, around 9000lm: * Nitecore TM9K * Imalent MS03 * Nightwatch NS53A The Astrolux EC03, Lumintop FW21 Pro and Fireflies E07 are all around 6000lm, so probably won’t make this list. Could a single 18650 the size of a D4 drive 3 XHP50.2 LEDs over 10,000lm?
The three bullet pointed lights that you mention: The first and third fit right in my hot rod collection, among the hottest rods for their size. The second one: I ordered two of them from my favorite USA supplier.
Lumintop FW21 Pro, 3 x XHP50.2 3V: Neils website says ~10,000 lumens, I submitted a serious inquiry to my fav light guy for three of them, he says he is checking on latching onto a batch of them.
Y, t a h n m f n r a n h g! Yay!
Agro
(Agro)
May 13, 2020, 6:17am
12
led4power:
You’re welcome to add these columns.
Agro
(Agro)
May 13, 2020, 6:28am
13
dave1010:
Nitecore TM9K
Imalent MS03
Nightwatch NS53A
Thanks, MS03 made it to the top of the list!
I’m not a fan of this brand but nevertheless I’m impressed.
Does anyone know tailcap diameters of TM9K and NS53A?
dave1010
(dave1010)
May 13, 2020, 6:33am
14
Added the NS53A’s tail diameter of 28mm.
Agro
(Agro)
May 13, 2020, 6:36am
15
I don’t see on your mods list. I’d like to add it to the table but I see that it is available with 2 different tails, could you please indicate which one did you use?
Thx.
samyy
(samyy)
May 13, 2020, 10:38am
16
The new Imalent LD70 - built-in battery (18350?), XHP70.2 and 4000lm this
CRX
(CRX)
May 13, 2020, 3:06pm
17
It was a short lived direct drive version with lighted tail . I didn’t make a thread.
Agro
(Agro)
May 13, 2020, 3:20pm
18
BTW, I find it curious that you got 1900 lm with SST-40 yet Vinh gets 1600 with XHP50.2 3V
CRX
(CRX)
May 13, 2020, 3:40pm
19
Direct drive, cracking bin LED, cell used, ANSI standard, planets aligned, different equipment...
I see vinh recommends to use the Vapecell 3A 14500, prob used that for testing.
I used a WindyFire red 14500. Don't get too caught up in the numbers.
dave1010
(dave1010)
June 5, 2020, 8:09pm
20
I liked this thread so much, I started a similar thread on pocket throwers over here: In search of the best pocket thrower flashlight (lots of research)
2A1
(2A)
June 5, 2020, 8:11pm
21
very interesting database, thanks for the insights.
Yup. He also did some amazing projects. Not only 14500 and when I read your post, the first thing I thought about was 458 HAM’R
the4ds9
(the4ds9)
June 5, 2020, 9:37pm
23
Thrunite TN50 CW is pretty hot. Its 4 21700 batteries are wired directly. The company rep told me they use LG. Wow imagine if it was VTC6A or 40T
patmurris
(patmurris)
June 5, 2020, 11:40pm
24
Thanks for this very interesting hotrod list.
I wonder how the FF ROT 66 Gen II w XPL HI would rank. It is supposed to spit out 14k lumen stock but it’s probably less. The light is quite compact though.
Agro
(Agro)
June 8, 2020, 12:46pm
25
I don’t think they’ll come close to the top…but you’re welcome to add them to the sheet.
I wanted to add it but there are no dimensions given. Anyway I actually don’t think it’s very hot compared to the small lights listed here.
Xandre
(Xandre)
June 8, 2020, 1:48pm
26
That one from Djozz is nice,too:
Not long ago I did a direct drive mod with this small AAA-size light . (details on the host can be found there, and in a thread about this light )
[image]
Everything very well connected, XM-L2 on copper, Efest 10440, it did over 500 lumens for 3 minutes (that is a significant part of total battery runtime already, 10 minutes at what I guess is 2+ amps). But, even tiny as the light is, 500 lumens is not always practical, especially since the beam pattern of such a small light with an xml favors c…
Regards Xandre
Agro
(Agro)
June 8, 2020, 1:54pm
27
Nice…but not very hot really. I added it now.
dave1010
(dave1010)
November 20, 2020, 11:24pm
28
The spreadsheet seems to have gone. Anyone got a copy?
