I tried that before as well while shrinking a MCPCB from 20 to 10 mm. After adding cushion to the jaws they wouldn’t keep it securely. Maybe a different cushion material would work better but that’s what I came up with quickly.
A double click on the button should ramp down the light from x (high) to y (off) gradually. Removing the finger from the button should stop the ramping somewhere between x and y.
Mine doesn’t do this. It is either on or off. Does this mean that the circuitry is shot? Is it resettable/repairable or have I just got a single mode torch/flashlight?
What’s the state of development on LEP? Do folks here think it’ll be a killer of LED-throwers? Might some makers combine an LEP (throw) with LED (spill) for the “near perfect” flashlight?
I've known them as channel lock pliers, but that's a brand name apparently. A quick google for either term gives a good idea.
Sorry the Knipex were half-joking. They are expensive, but an interesting alternative to a crescent or adjustable wrench. They are a particularly expensive example of a Knipex wrench - however, my Knipex tools are my nicest tools by far. I am sure they will outlast all my other tools, and me.
Please don't use those on nuts/bolts! Anything with teeth should stay far from nuts and bolts.
Slip-joint! Yes, heard that term as well. As for hemostats... Forceps to me! I use forceps routinely when soldering - it's a tricky thing to keep them from buggering up the wires.
What type of cell are you using? Alkaline, NiMh/NiCd, Lithium Ion, Lithium Primary?
Locking forceps make too much pressure, screws up the insulation.
Been using a variation of these and various other models (can’t find a pic / store with the lightweight aluminium cladded mini alligators) .
Pic clickable for link. Store has many other tools for the hobbyist. No affiliation.
Really though was using open-end wrenches for all the bolt heads I could, but the contours of the assembly kept it or a socket from fitting onto some of them. Improvisation was needed.
Not exactly. It is the “There are no stupid questions” thread, so stupid questions are allowed, but it says nothing about permitting stupid answers. Take this answer of mine as an example, it is not allowed. Belongs in the Joke of the Day thread, maybe.
I had two questions, but a read of the original post answered one question. So here’s my second question: why is it that small gas engines are so much noisier than large gas engines?
You might think the smaller engine is noisier because it’s usually higher pitched. Humans don’t hear sound linearly. We have what’s called Flecther Munsun Curves. We are less sensitive to lower frequencies so a larger piston tends to sound deeper and quieter while a smaller piston is more “whiny” and louder.
Also, smaller engines tend to have smaller mufflers so as not to reduce too much power.
