Locking forceps make too much pressure, screws up the insulation.
Been using a variation of these and various other models (can’t find a pic / store with the lightweight aluminium cladded mini alligators) .
Pic clickable for link. Store has many other tools for the hobbyist. No affiliation.
Really though was using open-end wrenches for all the bolt heads I could, but the contours of the assembly kept it or a socket from fitting onto some of them. Improvisation was needed.
Not exactly. It is the “There are no stupid questions” thread, so stupid questions are allowed, but it says nothing about permitting stupid answers. Take this answer of mine as an example, it is not allowed. Belongs in the Joke of the Day thread, maybe.
I had two questions, but a read of the original post answered one question. So here’s my second question: why is it that small gas engines are so much noisier than large gas engines?
You might think the smaller engine is noisier because it’s usually higher pitched. Humans don’t hear sound linearly. We have what’s called Flecther Munsun Curves. We are less sensitive to lower frequencies so a larger piston tends to sound deeper and quieter while a smaller piston is more “whiny” and louder.
Also, smaller engines tend to have smaller mufflers so as not to reduce too much power.
This may not be budget but will just change the lens to black one, https://www.allmoparparts.com/sku/264274bk.html. It is from Recon and the price is not too nice and would it be a best choice for a recon light? Also, not sure if it legal to have one lens to be black and the other white…but would hope I can do that.
I would see what the cutoff pattern looks like. I’ve seen a lot of jeeps with projectors that just glared oncoming traffic like crazy. If these give you a sharp cutoff pattern and they are adjusted right, they might be okay.
Virence doesn’t appear to have flashlight-sized and -shaped LEDs, unless I’m misunderstanding the pages there.
I’d be looking for 20mm stars to drop into existing flashlights replacing the cold blue stock emitters.
His page seems to offer the largish square emitters which wouldn’t work with normal reflectors.
Virence’s CRI offerings do seem to be better than anything I’m aware of.
144A is a straight swap for an XHP50/50.2, 219 and 319 are 3535 pad. Optisolis and E21A are similar to XP-E or smaller and work well in small lights that have low current like AAA keychain plus he also has “quadtrix” boards for them that allow 4 to be mounted very close together and centered in a large enough reflector or TIR in an S2, Skilhunt H03 and similar.
Yeh. I grabbed the narsim .pdf, and in the “advanced configuration” table at the extreme-right, the 2nd option is battery-level by indicator-light only.
Gotta follow the blue arrows, I don’t wanna try “interpreting” it and have you initiate the self-destruct feature.
