what makes you think that?
- YouTube
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.
I have a c8g I have been waiting on for little over two months, may have been lost Idk
Aha. Therefore, resistance is not futile!
Lol
I got my LT1 a week ago. Bought in sofirnlight, in Russia the package reached in 35 days I consider it a very good result. Tremendous lamp! Latest version, 5.0. I use it every day, it ’s like a toy, I ’m really happy.
Barry posted some color sample SP40 pics on the color thread “”https://budgetlightforum.com/t/-/72853/142”“:https://budgetlightforum.com/t/-/72853/142
maybe colored versions aren’t much farther off now?
maybe colored versions aren’t much farther off now? :partying_face:
Those could be a possibility.
Has anyone tried bridging the drivers 6 and 7 to increase the max brightness by using pencil? Can anyone can show the picture of how it’s done? I’ve done it but not sure if I did it correctly as the brightness isn’t noticiably different. And I measured the lux by using my phone and I got more lux at mid CCTs than at 5K CCTs. Is that normal?
I’m interested in getting 2 or 3 of these. I’ve been aware of the project but I have to admit I haven’t followed it very closely. What is currently the best way to get these?
Not sure if anyone has them in stock stateside but from Sofirns website has the best price.
Just bought one from amazon canada shipped by amazon . If available in amazon us. PM sofirn for a discount code . Ended up same price as sofirn but with fast delivery and no hassle returns .
So I tried to search the thread, but didn’t get anywhere. My LT1 spends a lot of time on my nightstand, because the soft warm glow is fantastic. However, I’ve noticed that even if I haven’t used the LT1 all day, when I turn out the lights the diffuser appears to glow slightly. Has anyone else noticed that (and/or does anyone know why that is)? I have LED bulbs in the room with similar-appearing frosted-plasticky diffusers that don’t exhibit that behavior, even if they’ve been on all day. Is there a tiny bit of GITD powder mixed into the diffuser?
Does it continue to glow if you unscrew the battery tube from the head. That should eliminate if it is caused by some sort of an electrical leak causing the glow or something that glows without power.
Finally remembered to check this after dark with the lights off - that is, when the “glow” was visible. The glow disappears when the battery tube is unscrewed.
I keep meaning to open it up, but I’m never near hex wrenches (to open the top) when the inspiration strikes. Then I get distracted… I at least checked the topside of the driver just now, and nothing looks out of place.
As for the adjustments on the solder bridges: Are 6 and 7 on a separate channel from moonlight, or would bridging them increase the brightness of the lowest level? I really like the low, warm output as a bedside lamp. I wouldn’t mind a higher high.
Brightness isn’t completely flat while changing tint. It tries to adjust output to keep the brightness close to the same, but it’s not perfect. Brightness is expected to be slightly higher or slightly lower in the middle than it is at either end of the tint spectrum.
Going from 5 to 7 chips causes all levels to be 7/5ths as bright as before… including moon.
But at only like 1 lm to 1.4 lm, it’s not a big difference at the low end.
Why is this so expensive? I checked amazon.ca and it’s a hundred bucks!
pm sofirn for a discount code . with batteries it’s $81 .
Carry case for LT1 is availble now! Buy LT1 and case together, save $2.5
Carry Case Link: https://sofirnlight.com/blf-lt1-p0013.html
Thanks Sofirn,
$55 w/case…… thats a good deal! …… I already have one but plan on two more when colors are available(OD green & Desert tan)
Im half tempted to order another lantern to see if the new shipping process will beat my light stuck in Nanning.
Not sure if anyone noticed the SOS Mode?
Driver Rev. 5.0 is installed.
After Beacon Mode there is the SOS Mode.
Where normaly the Temp Check can be found in Anduril Flashlights.
Thanks for this great project.
Regards,
Robert
Success! After 6 months and a replacement shipment later, I finally have mine!
It’s incredibly well built, definitely worth the wait.
