This is great news
I may be interested 2x17mm and at least 2x15mm, in case you can ship them internationally.
Would it be “good to use” with other leds too? (ex: Luxeon V2)
Thanks for your work
This is great news
Yup, any 3V LED should work well.
I ship internationally. The first batch went overseas. But unfortunately the cost is high (around $14 usually). Domestic shipping is around $3.50.
Great
Hum, I know it is a bit more expensive, I had to pay that when I ordered from MTN, but I don’t mind!
So, in case you accept my “order” (whenever you can make and ship them), I would definitely get 2x17mm and 2x15mm! :+1:
Hmmm tempting, although I have no suitable hosts atm and shipping is a bit pricey. Maybe if there were a lot of UK/EU demand we could do a group buy and have one person this side of the pond re-ship them?
Yeah count me in for a couple! Maybe 3-4 unless you need more to help fill a quantity.
you have to be careful of one thing: alkalines are much more likely and fast to leak when completely discharged
if you let it run down, and then forget for some reason it is sitting there discharged, it might make a huge mess…
wle
Alright, looks like there’s a bit of interest. So I’ll establish some pricing and get a list going. After gathering a list for a few days, I’ll order the parts to assemble however many I get on the list. I’ll try to keep this post updated.
Pricing: $4 per driver including spring and wires (TLV61220 version) or $3 (ZXLD381 version)
Shipping: $3.50 for US, $14 for International
When making your request, please specify:
Request List (as of 2020-05-18 10:44 AM CDT):
Sweet! Thanks again
To specify the order:
- 1 x 17mm x TLV61220 version (0.3-0.5 lumens)
- 1 x 15mm x TLV61220 version (0.3-0.5 lumens)
Are these values (lumens for the specified driver) reasonable?
Please do so I can see if I can source the parts and attempt to build myself or if I’m better off ordering from you!
I just added the BOM to Post 72. It’s a pretty easy assembly and the only specific item to locate is the boost IC which is widely available.
Also… bump in case there is any more interest out there
Thanks gChart!
Funnily enough the sense resistors are the hardest things for me to source in small quantities for a reasonable price.
So I’ll probably do the same as MascaratumB and buy four (one of each combo) direct from you.
Output wise I’m thinking of 0.1-0.5 lumens and 3-5 lumens with sliced SST-20 2700K JA3 and 4000K FB4. Would it be possible to buy extra sense resistors from you at the same time? Will be useful to tweak output in the future based on LED.
Based on my limited knowledge it looks like this driver doesn’t really have any brains so I assume additional modes are out of the question? How about lit tailcaps?
Thanks for sharing this driver gChart!
I stumbled across this board recently when I was poking around OSH Park looking for joule thief drivers for 5mm LEDs and I’ve been meaning to ask you about it.
You’ve come up with some really great stuff lately. After you sent me some booster tail boards I ordered your LVP version. I finally got around to assembling it a few days ago (my first PCB assembly) and now I’ve got some of your indicator boards on the way.
Would this driver work with a red LED, or would the lower voltage be a problem?
Do you think it would be feasible to make a 10mm version for AAA lights? A couple of times I’ve purchased really cheap single mode AAA lights just to put the driver in a (slightly) nicer host that came with a high/low/strobe driver.
Typically what we call sensor resistors are low-Ohm, high-wattage buggers that are expensive and less common. In this driver, though, a run-of-the-mill 0805 1/8 or 1/16 watt resistor like you can get in bulk kits from places like Banggood, AliExpress, eBay, or any electronics supplier for like $0.01 each will work just fine.
I can definitely build them and send them your way. But if you can locate the parts locally, it’ll probably be considerably cheaper to do so.
Nope, this was designed to be extremely simple with no modes… just extended runtime. Running an MCU would require extra power and would decrease runtime. Lit tailcaps are also a no-go (unless perhaps my “booster tails”) as they would still be seeing the ~1.2 volts of the battery, no enough to run a typical tailcap.
Lower voltage shouldn’t be a problem. It should operate LEDs with a vF anywhere between 1.3 and 5.0 V.
I think so. I can play with the layout and see if 10mm will fit. Some AAA drivers have lobes on them. Are you thinking completely circular, or odd-shaped like that of the Astrolux A01 or Lumintop Worm or Tool AAA? Do you have a specific host in mind?
Ah ok thanks, let me look into the resistors again.
For the capacitors I found 6.3V and 10V, does it matter which one or will both work?
Either is fine.
I’d probably go with 2 0.5-1 lumen and 2 in the 3-5 lumen range. Let me know when you are ready!
Ok. Diameters?
Do you have an Oshpark link and BOM for the ZXLD381 version as well?
Yup, here ya go
https://oshpark.com/shared_projects/eRMnLVjU
BTW, I found some 381’s on AE. Granted, it’s for 30 pieces. So yeah… I’ve got 30 of these sitting around unused.
My SpiderFire C-013 used to work down to 0.7 Volts. However, it needed something like 0.9 Volts to turn on first. I actually fed it weak AA batteries. IIRC, the one I had was advertised as a 3-mode but ended up being a 5-mode.
