Ahah, thanks
Your wallet won’t thank you, probably, but your EDC kit surely will Ehehe!
Thanks for the comparison
It would also be nice to have an Olight S2R (I or II) to compare it with this light, as both have the same form factor, side switch and all that.
Answering you, by parts
1)
a) the switch is not as resistant as the Emisar D4 or the Olight M2R Warrior, or even the Wuben TO50R or TO46R. Both these have rubber caps over the switch so this may be a factor in resistance. You still need to press it slightly to activate, but it doesn’t need a lot of strength.
b) well, accidental activation is something that I didn’t experience because I normally use it locked, so it didn’t turn ON in the pocket. BUT, in case you use it loose in the pocket with other stuff, it may happen. If clipped to the pocket, or loose without other stuff, that possibility will probably decrease
c) the design of this light is very nice in terms of location. If you are using it with index and thumb you’ll find out that having the button up or down won’t necessarily matter because you’ll be able to activate it with whatever finger you have on it Also, I am using mine with the pocket clip in the opposite direction of the button, so whenever I grab the light, I’ll know where the button is. But even without that, you’ll be able to touch the switch and activate it well due to the shape of the head.
Check this photo I put above:
2) About the pocket clip and tube…as the tube is glued, I didn’t mess with it. However, looking at the bottom end threads, it doesn’t seem to me that it can be reversed.
The rear groove has, more or less, 2mm in height and the diameter is similar to the one in the head, 20.3mm:
!https://i.imgur.com/MUqIYRP.jpg !
Hope this helps.
BTW, due to the tension created by the pocket clip, it cannot be used “cover” the switch to hinder accidental activation. The clip presses the switch activating it!
