Thanks for the schematic. I was wondering what F2 was being used for but still don’t see the need for it.
I believe the original driver switched at 300khz, it would be nice if that could be increased. Maybe replacing F1 with a Schottky diode might be easier than trying to figure out the band gap between F1 and the pfet. The band gap may need to change with load and temperature, and there could be some shoot through if the attiny gets too busy.
The attiny 1626 and 1627 are almost available. 20mhz clock speed and 12 bit adc would be nice for this application.
I was looking at a micro-driven switching controller a couple weeks ago but, with the chips I have available, couldn’t get a sufficiently high switching speed and decent resolution at the same time due to hardware PWM limitations. 6.8uH inductance probably helps with that; I wanted to stay under about 2uH to get high saturation and low DCR in a compact package for a 17mm driver. Slick use of the analog switch as a gate driver too.
The 1616 has a 10 bit adc but it may not matter if you are using an op amp. The little bit I have read about the two series claims very fast adc conversions and a more powerful cpu. Either one would be an improvement on the old 85.
My biggest concern is the attiny could be spending too much time on other tasks and not spending enough time on the boost converter. If this thing works and the switching speeds can be increased it opens the door to higher power versions and maybe buck boost as well.
Its impressive that you have got it down to 18mm. Is there a reason you dont want to go double side?
This design could easily fit 17mm if you stuck some of the smaller components on the oppisite side. Just leave the center for positive to solder on a copper stud or small spring.
In time, I think Aundril will be adapted to work with boost. There’s a few members working on it.
