Agreed - hope the pogo pin flashpad thing is high on the priority list. It really should be/has to be.Therefore the re-programming pin access is important for a couple possible reasons:
they probably would use a small footprint MCU to save space
the smaller the light, the more difficult it could be to get access to the top side of the driver
firmware tends to be evolutionary
not sure if anyone has done BLF firmware supporting 2 different battery types; NiMh and Li-Ion, so not sure if detection can be implemented. I see on other AA boost designs that LVP is supported only for the 14500, not the lower voltage batts, so could be a technical limitation, maybe?
Though it may be safe for the cell, still seems weird not to have any notification because if the boost chip drops out, I would think the light just turns off with no notice.
If I remember right the PAM2803 boost IC that alot of these AA lights use drops out about .7v shuting off the light. It does kind of give a warning at around .7v where the light output is getting really dim before shut off.
I’m kind of wondering if going that low might be a problem for the mcu.
Interested. Would love to see Andruil ui or some kind of ramping os in a blf version of this light. Would be the ultimate carry if it could also work on nimh AA, but I would still buy if only 14500.
That’s great news gchart and thank you for helping carry on the project. Do you know if the boost ic has been picked?
Is it the PAM2803 or something different?
There’s been a bit of talk back and forth on the overall design. As it currently stands, I think the plan is to keep most of the driver the same, just replacing the PIC with an AVR and a little rewiring to make the new connections. A couple minor tweaks are being looked at. Things like the boost IC don’t have any planned changes to my knowledge.
I am curious if the design will retain Andúril's (three clicks from off) "battery voltage blink-out" or Andúril's (built-in) "low voltage protection for Li-ion batteries".
All the "AA/14500" compatible lights I am aware of do not have built-in low voltage protection in order to allow operation with the lower voltage AA batteries and recommend only using protected 14500 Li-ion batteries because of this.
I do not mind using protected Li-ion batteries, but would sure miss being able to check the Li-ion battery's voltage while the battery is still in the light in order to determine the approximate remaining capacity.
Thanks to all those advancing this project towards a successful reality.
