So, is there a current, very popular 14500 light on the scene?
I will have to have a look at the RRT-01. Can it do warm, high CRI, flood? I’m about equally good with 14500, as 16340, even 18350. I just want fairly compact and rechargeable li-ion, not primaries.
The light I lost was clipped to the corner of my pocket. It was found by someone else, later, who realized that it was mine.
Now, with the lanyard, I drop the light into my pocket and never worry about losing it.
Would recommend looking for the old model rrt-01. The new one is very heavy and bulky, certainly compared to the eagletac.
Yeah… EagleTac created a masterpiece with the D25 line. I just wish you could get them with warm & high CRI emitters. Mods are possible on at least some of their lights, though.
I also have great appreciation for Olight’s S1A Baton with TIR optic - pop a 3000k XM-L2 under that TIR and the floody beam and warm color are magnificent! Great compact size, too.
I still carry and love my Utorch UT01. Somewhat programmable. Simple. Great battery life. Compact. And takes both AA and 14500.
The LED is easily accessible (2019 RRT01). I have not even had to disassemle the head completely to get to the MCPCB if memory serves. Not sure if there’s a TIR optics that would fit. The reflector geometry makes a more narrow spill. Best would probably be to stay with a domeless LED, else it might have some artifacts in the beam, but that’s just a guess based on my experiences with other deep smooth reflectors.
Check out the Jetbeam Jet I Mk
I have a Jetbeam Jet I Pro, from about 8 years ago. Great little light, but it’s most definitely a thrower. Deep reflector and tiny XR-E emitter.
Perhaps it could be customized into a floody, warm tint light with an XM-L2, textured reflector, and a TIR?
The bezel is removable, but I don’t know about finding a textured reflector that would fit, or making a TIR fit, somehow. I guess I could ask Vinh to mod it, though.
:open_mouth:
Want one.
I put a 20mm convoy tir lens in. Easy drop-in only a fat oring is needed under the bezel ring to compensate a small height difference.
Again, I really doubt you will like it as an edc. But there are even people happy edcing a HDS.
Will lose most ability to mod with the Ti versions.
The bezel is glued, so you will need appropriate tools, with appropriate protection for the light so that the tools don’t scratch it.
It’s sufficient to remove the bezel. That’s how I did it.
If you can’t change the LED yourself, cheapest and easiest way to mod your light is add DCFix to the front of your lens.
Thanks Pavlo. I have enough ability to change the LED, what I don’t know anything about is getting different reflectors and/or lenses/TIR and fitting them to the light. I need to get more education on doing those kinds of mods! :sunglasses: I would love to mod my Jet I Pro to be warm and floody, but I don’t think I would be happy just obscuring/frosting the lens itself. I would want to do it right.
+1 for this.
Very handy little light.
I just got a Sofirn SP10S today. Love it! The only EDC light I know of with a Samsung LH351D emitter, 90 cri 5000k. It has a super nice beam quality and on a Ladda cell is pretty bright for an AA. I can’t wait to try it with the 14500 if they ever get here from across the pond…Fit and finish are excellent, plus has AR coated lens. For $18 shipped on Amazon it’s a steal.
The Skilhunt M150 also has that kind of led :wink:
https://www.aliexpress.com/item/4000828485118.html
My unit had the XP-L HD CW, but the High Cri version is also available :wink:
So any negatives about that light that you found?
Sp10S very tempting for me now.
The only one I can think of is it comes on in my pocket, but you can lock it out by unscrewing tail cap slightly, or tap the switch 4 times quickly. Otherwise it’s perfect as-is. Waiting for my 14500 for access to 800lm turbo! I tested it alongside my Sunwayman light with the xp-g2 and thre beam is nicer thanks to the high cri.
I just got an M200 with the ’351. Niiiiice. I hope to stick a review on here soon.
For an 18650 light, it’s actually a bit shorter’n my GTmicro (14500), but of course the ’micro has the wide head.
