Yes, asked for it via chat and did custom order
Bling!
A light that tics a lot of boxes for me:
Rotary with stepless ramping
High CRI sw45k
Sapphire lens
eSwitch
multi fuel: Cr123/16340/AA/14500
Tritium locators
Firefly of less than 0.005 (as low as an RRT-01)
max of 200 High CRI Lumens
Bling!
Wow Jon. Where do you find all these gems?
18350 tube.
SS bezel.
3000k sst-20 with zircon minus green filter.
Red Glow.
Agro:How is the MOSFET cooling?
It sits on top of a fairly large copper pour which should hopefully spread the heat out and into the body. And with it being limited to 3 amps, hopefully the FET won’t be needing to dissipate more than 2.4 watts or so (4.2V battery, ~3.4 vF LED… so 0.8V dropped across the FET at 3 amps = 2.4 watts… if I have my math right). That’s a far cry from the 15+ amps that a lot of people are trying to put through a FET.
I just put this thing together at 2 AM. I still need to put it through it’s paces (thermal testing, etc).
I see, thanks for the answer.
Bling!
High CRI sw45k
Sapphire lens
eSwitch
Tritium locators
How can you possibly have the trits showing in that photo? UV light applied to them?
yes UV
no UV:
Scallywag:How can you possibly have the trits showing in that photo? UV light applied to them?
yes UV
no UV:
Thanks - that is an excellent comparison! I knew sometimes UV was used in such photos to show trits, but (and especially before owning any trits) didn’t really know how great the effect was, or how to tell in pictures.
Don’t forget, for FET you can buy a GT Micro driver from Lumintop aliexpress that drops right in. I couldn’t get Anduril working when I tried to re-flash it though but the stock GT Micro firmware works fine.
Do you have a link for the GT Micro driver? I looked on aliexpress but couldn’t find them. It would be nice to get my 2 UT01 lights working properly without having to unscrew the tailcap all of the time.
Lumintop TiTool LED swap to sw45k
FW1A pro w/ tir and o-ring switch mod
How’s the beam profile with the TIR vs the stock reflector? Where’d you source the TIR?
vinte77:FW1A pro w/ tir and o-ring switch mod
I found the tir in my spare parts bin, so I’m not exactly sure where I sourced it (it could’ve been kaidomain or fasttech). I had to use an o-ring to fill out the space as the tir was slightly loose without it. I also removed the led ring in the install and there is no problem unscrewing and screwing the bezel on and off, not twisting the MCPCB and wires. The beam is narrower. The outer circle of the beam is less green but there a yolk in the center. Overall, it looks better to me but I’m a sucker for tirs.
EC01
–4xXP-L HI V2 5D 4000K
-LEDIL ANGIE-M QUAD
Awesome mod andrx! Definetely will copy this. Did you made your own spacer?
andrx:EC01
-LEDIL ANGIE-M QUADAwesome mod andrx! Definetely will copy this. Did you made your own spacer?
yes a piece of aluminium
DarkShot: vinte77:FW1A pro w/ tir and o-ring switch mod
Any beam shots with the TIR?
vinte77: DarkShot: vinte77:FW1A pro w/ tir and o-ring switch mod
Here you go, but the picture isn’t the best since it’s from my phone and I don’t take the best pictures.
I put 219b 4500k in Wuben E05 today. What can i say. I do not recommend! Beam is terrible, not equal and has lots of artifacts. In the picture it doesn’t look as bad as in reality.
Thank you for the warning!
Noticed the same in the A6. Dedoming the LED did nothing about it. Samsung LH351D works well in the Wuben.
Edit: Cured the A6. 219B sw45k D200, honeycomb optics, led4power 3A driver and illuminated RC.
