Will publish the final specs in couple of days.
ohhhh mini me
Interested in XHP50.2 version.
I assume that being a FT03 (mini) implies that it does have USB-C charging?
For me the smaller head could be precisely the reason to buy it, already have the GT-mini in that size.
But in the end I probably let this one pass me by because it is too long for my taste. Unless the reason for the length is a really nice deep reflector of course.
Interested!
Would love to see some 3535 emitter options - not really anything great in the 5050 realm. If only Luminus could get rid of the green in the SST40.
Interested in xhp50.2 version.
Interested.
I like the 18350 body tube knurling It’s a good change from the usual diamond pattern.
Yes, that’s how the 18650 tube should also look like.
Interested in the blue SST40 version.
RGB Aux and 18350 tube are a big plus.
Interested
XHP50.2, 4200lm, 51000cd, 452m
SST-40, 2300lm, 85000cd, 583m
RGB Aux Leds
5V2A Type-C USB Charging Port
Anduril UI
18650/18350
This is what I got from Mateminco
Interested
I’m in but only if 3535 or sbt90.2 is posai le to install afterward.
Crapy 5050 emitters are not my option at all.
They’d need to provide new centering rings to make it 3535 compatible - given they’ve also integrated aux LEDs, I don’t see that happening.
I still want a replacement centering ring for my FT03
Go to the Mateminco store on AliExpress and ask
I’m not sure how good XHP50.2 would be in something so small. The FT03 only could handle 2 minutes Turbo so the mini will be way less
Interested!
