Do you have a link for the GT Micro driver? I looked on aliexpress but couldn’t find them. It would be nice to get my 2 UT01 lights working properly without having to unscrew the tailcap all of the time.
I found the tir in my spare parts bin, so I’m not exactly sure where I sourced it (it could’ve been kaidomain or fasttech). I had to use an o-ring to fill out the space as the tir was slightly loose without it. I also removed the led ring in the install and there is no problem unscrewing and screwing the bezel on and off, not twisting the MCPCB and wires. The beam is narrower. The outer circle of the beam is less green but there a yolk in the center. Overall, it looks better to me but I’m a sucker for tirs.
I put 219b 4500k in Wuben E05 today. What can i say. I do not recommend! Beam is terrible, not equal and has lots of artifacts. In the picture it doesn’t look as bad as in reality.
Tried to repair my Lumintop GT90.... and failed.. replaced the LED but now the Driver is smoke... (or something) The light turns on... and ramps up and down... (although still very bright in the lowest output) and it doesn't turn off anymore.
Nice look!
Is your lanyard ring loose or firmly in place? Mine spins… and body is tightened down fully. I’m not sure if I have a different cut from an earlier batch, and if the thickness was increased later.
Relatively minor but it’s my favorite project and it’s finally finished. Added a bezel up clip and a made a flat button out of high temp silicone rubber. Now it’s exactly the way I want.
The one I bought was the second one pictured, short titanium crenelated. I really like the first one too. Emailed him and he still had stock left, at least when I reached out.
