Just out of curiosity but, since you are speaking of S21 (S21A?) triple spacers, what is the suitable TIR optic for a S21A triple? I have an unused S21A host lying around I still haven't thoroughly examined, although the bezel opening measures ∅19.8mm with my cheap caliper. So am I guessing right if the same Carclo 10507 and others alike?
I just wanted to say that I guess my package was processed yesterday in Portugal
So, it moved slower than normal, but is coming my way !
I’ll let you know when it arrives!
Thanks for the attention :+1:
When I received my Triple SST-20’s from Kaidomain, they also gave me a set of optics to go along with them and they seem to fit just under the glass.
Something for me to try before I tumble into another rabbit hole
Thanks for the information on the optics from Kaidomain KnHawke and treellama, will have to try a triple sometime. Knowing myself, it'll have to be fully regulated, with boost driver and series emitters.
In any case, I guess that triples are on the floody side of beams, ¿isn't it?
Not a problem!
The Triples I got are in Parallel (I think that is the proper term {I’m tired atm lol}, still 3V but draws more amps) and I’m gonna use a MTNElectronics FET+7135 driver, should make for a good pocket rocket with the S21A (The flood will likely be the same to the OP reflector that it come stock with)
when my 4x18a arrives i’ll be able to provide dimensions but if a custom centering ring for a 32mm noctigon for the 4x18a would be possible… a simple spacer to fit into the head to center the mcpcb i’d add it to my next
Yes, it is smaller. The idea is to fit a piece of copper into the original mcpcb area and install the larger mcpcb over it with a ring surrounding it and screwed down to hold the emitter centered.
