Just a quick update. I've been playing around with this flashlight the last few nights. Just like my SkyRay KING, this light can run on 1 to 3, 18650 batteries thanks to the parallel carrier configuration. The flashlight can be used to recharge 1 to 3 batteries too.
Even better now, Rather than plug the USB charge cable into my computer, I've been using my Apple 1000mAh wall charger that came with the iPod Touch, and even the 2000mAh Apple USB charger worked perfectly as well.
Best part about this, my flashlights that require 2 or 3 or even 4 18650 batteries, I've been using this flashlight to balance charge all the cells. They always come off charging inside the light at 4.19v, whether one is being recharged or 3 of them, again thanks to the parallel battery configuration. For the first time in well over a year, my Genuine Trustfire Flames 2400mAh cells actually have a static voltage exactly the same.
Lastly, the brightness of this light is attributed to its constant current regulated output of 2.8A (8*7135)
Thank you for the review. That is out standing. Now I just have to convince the wife that this is the flashlight SHE must have ;-)
It seems like a really good item - but after having a little while and using it how would you describe quality of the exterior? And handling in general. (I read the review but often I change my opinion of things after owning them and using them for some time. Maybe that is also the case here?? )
Hey LedSmoke, Well, my wife really likes it and mentioned how very bright it is. Although she doesn't like tail-switches, she did comment it's easy for her to press the switch and doesn't take a lot of pressure to turn on like some of my other lights.
As for handling, between the diameter and the excellent knurling, I honestly feel it's perfect. The diameter is similar to a "D" size flashlight. It's always felt very solid and of high quality. When I have extra money to spend, I'm going to purchase some Redilast 3100's for it yielding exceptional runtime and or charging capacity.
Hi Pok, that's a really nice sweet spot to run an XML. How did you manage to get such an exact reading?
I didn't look closely enough at the IC's, I'll take a look when I get home, but if you say they are 380mA, I'm sure you're correct. With that current, it's got to be putting OTF 800+ lumens after loses?
Thx for the great review Richie! This one has caught my eye since I have a camping trip coming up and given the single 2200 mAh 18650 in the Poldera PowerBank, it won't charge my iPad. That's great that you have tested this to work.
Hi Pok, I made that same mod you mentioned in your thread you started for this light regarding the battery carrier. I added some washers to one end to make inserting and removing the batteries easier. I used very small lock-washers pounded flat with a hammer so they sit completely flat prior to screwing them down. Works great just as it did doing the same thing to my DRY flashlight.
Also, I checked the IC's on mine labeled, 7135 and below that is 35B. I can't seem to find out what 35B represents. I did check my Roche F12 that has the same 7135 driver but without one 7135 IC and outputting about 2.5a, which is labeled 35C
Quality appears first rate, and it will be so convenient to be able to recharge without removing batteries. Put in three identical 18650 and these topped off quickly through the mini USB. Checked the charging output from the USB A port and this worked fine with my Nexus One phone.
My 7135s have a 35A label. Measured 2.8a, 0.8a, and 0.1 using a precision power supply.
As mentioned earlier here, there are three levels in the light pattern - the central is well defined for throw.
No complaints and pleased to employ more of my 18650 batteries.
Hey Pok, if you get a chance, after you recharge your batteries inside the flashlight, can you do a voltage check on them. I'm curious to see if there is any variation between your light and mine. Charging 3 batteries, it always tops them off to 4.19v.
nice beamshots. when I buy this light I'll probably order a good diffusing lens. I like a floodier beam for camping and it'd be a shame to lose output in such a great light.
