2 emitters for white light and a third one for RGB?
That makes much more sense, what kind of options are out there for larger RGB emitters? I have only ever seen the XM-L Color but there has to be more from other brands right?
I have 3 of them - this has not happened on any of them
Keep getting error on that form. I’m interested though. Would like some more details though. Nice that it will cost somewhere between 10.99 and 99.99.
Interested depending on more details - The title does say XPL-Hi v3. so the only question is the aux lighing and how bright the aux lighting is. Assuming only white reaches 1200lumens. Not any of the aux colors.
I heard the 2019 version drains the battery in a month or something like that.
Measured parasitic drain of the 2019 RRT01 and it was quite low, in the range of lights with electronic switches. Thought it was higher due to the sensor readings.
Interested.
Interested, form is not working. Would be nice if the floody led could be high cri.
works for me
Interested
Interested.
Jetbeam = Nitecore not long back, this would make a good D10/D11 replacement or even the new RRT01 Raptor Tactical especially.
Interested.
Mode selection
Interested
Interested.
Interested.
Mode selection
Are the sections between “Low / Middle / High” infinitely variable (smooth ramping), or are they set indents (stepped output)?
If the latter, what occurs between the indents, ie. stays on existing output, moves to next output, or light is off/no output?
Many thanks for another cool Group Buy…,
Normal with all the Rotary Jetbeam lights I have seen when its listed like this it’s 3 modes L, M, H and it does nothing in between. By nothing, I mean It just stays in the existing mode until you turn it far enough to activate the next mode.
That would make a huge difference in the way this UI works, if its infinite brightness or not.
Freeme could you please verify the UI?
The JetBeam RRT-0, 01 and presumbaly 02 all had infinitely variable output with the magnetic ring. It’s why they are so highly coveted by many.
This light not having that in favor of discrete modes on the ring will be a hard pass for me.
interested
