What did you mod today?
I knew the TO50R had quite the driver, as it was a high-output quad without our simple FET approach, but didnā€™t really know any details about it.
What a monster. I want one even more. But I donā€™t know if my budget will ever overlap its price point.
It seems that Wuben has great and well structured drivers! :person_with_crown:
This is Tom Eā€™s photo of the T70 driver:
Posted here: ā€œREVIEWā€ - WUBEN T70 Camouflage ā€“ XHP70.2 Led ā€“ 4200 Lumens [PIC HEAVY] ***Extension tube = 2 x 26650*** - #14 by Tom_E
BTW, gchart, when I got my first TO50R sample for review, I had some ā€œelectronicā€ problem that after turning it on in Turbo 2 or 3 times, it stopped working on the Turbo level, I could only cycle between some modes (ML-L-M-L-ML - yeah, it was acting weird too!).
I sent it to Wuben again, to China, and they sent me another one! Jelina later referred that there was an hardware problem.
I do hope you can manage to make it work again, fully, and with those extra leds :wink: It looks great! :+1:
Itā€™s a Wuben E05-I (TLF-version with much improved UI and Samsung LED). The 5000K LED was too greenish, so I decided to implant a 2700K LH351D. Hestitated a long time since this is or was a collectors item. My good taste won eventually.
You got one of those :o
I saw them on selected-lights but never ordered! The UI is better than the regular version, I am sorry that that version was never ā€œimplementedā€ in larger scale! :zipper_mouth_face:
Better tint now :wink:
Good taste indeed!
Thank you, guys :blush:
This light is often offered in the sales section of the TLF. Just in case anyone is looking for it desperately.
wow very cool gchart!
I decided to try an ammonia forced patina on my copper Olight i3t.
It was a spur of the moment decision after I absent-mindedly rubbed it with a rust eraser and wasnā€™t happy about the bright patch. I definitely could have done a better job with five minutes of prior research and preparation, but in the end I didnā€™t mind the result.
More photos of the process here: Olight i3t copper ammonia forced patina - Album on Imgur
I think its cool, and if you dont like it, just polish it.
First [light] mod at the new place! WF2 in a BLF D80 V2. This is on my barn varmint gun. Iā€™m super happy with throw, itā€™s doing 128kcd but I have no way to measure lumen output. No centering ring for proper focus, just 2 layers of kapton for electrical isolation.
Iā€™ve got more of the WF2ā€™s, gonna toss one in the X6 on that 9mm Camp carbine, itā€™ll serve as the garage varmint gun (cause Iā€™d rather not shoot 5.56 in the garage / next to the house). Iā€™ll be happy if I get 90-100kcd from the X6 when I can get some spare time to swap it.
TrueRMS, nice job with the WF2, looks centered to me. Looking forward to seeing some beamshot in the X6, I donā€™t have ā€œflatsā€ in any light yet.
My mod today, an Olight i5T.
I like and carried the Olight i3T since it first released, so I was excited when the i5T was announced and picked one up during the first Olight Covid-19 charity drive. It was pretty much what I expected, a larger longer running AA version of the simply forward tail-clicky 2-level i3T, nice. The only thing detracting from this excellent light was the green tint-shift, so I decided to tackle an emitter swap.
I replaced the original cool Osram P9 emitter, which is a nice clean/cool white tint by itself (when viewed without the optic/lens in place) but as mounted in the i5T with the optic, suffers from green tint-shift. Perhaps it was an action-reaction thing with the cool white because I decided go in the opposite direction with a warm LH351D 2700K emitter for this reflow.
On the photo left is the view of the inside of the i5T with plastic lens and optic removed. The lens is press-fit so thereā€™s no easy way to gain access without sacrificing the lens to get at the emitter inside. Similar to the i3T, Olight once again used a wireless post-through-the-MCPCB method of mounting. Clean looking but tricky to re-work.
On the photo right is the final light with warm LH351D installed. I salvaged the lens the best I could with repairs using optical epoxy. I have a glass replacement lens on order and will replace it later.
This was my first installation of such a warm emitter. For those desiring incan-like color temperature, the LH351D did not disappoint. Here is a comparison of the 2700K LH351D (on the left) with a real Surefire incan P-61 (on right); a 5000K neutral is on the bottom between the two for reference. The wider hotspot from the optic gives the illusion of the beam being slightly warmer/more orange than the focused incan hotspot. Frankly I found it a little too warm and may opt for something in the 3-4.5K range when I replace the glass.
(Continuation from post 9028) Eureka! So, the TO50R driver must have been monitoring current where I had tapped into the ground. I found a true ground connection and now moonlight works again!
Congrats. Really nice, I wish I could do this kind of magic. And thanks for showing the innards. Maybe that justifies the breathtakening prices Wuben takes.
Agreed. At first I thought Wubenā€™s prices were nuts. But that driver really shows that theyā€™re not messing around. They have been in business for almost 40 years which is pretty respectable for a Chinese flashlight company. Theyā€™ve certainly got experience.
Nice work pc_light. Iā€™d like to do the same but Iā€™ve never been game to crack open an Olight before.
Do you have any more photos of the process, and could you post a link to the replacement lens?
I didnā€™t take any in-process photos, I just dove in not sure what I would run into. Before I realized it, I was done.
I can describe the process. I drilled two tiny holes into the plastic lens on opposite edge/sides about 1mm deep. Then used some fine nosed tweezers to work the lens off. I used dual holes in case I needed to twist but as the lens wasnā€™t glued, perhaps a single hole would have been fine. In any event plan on replacing the lens when done, itā€™s soft plastic and would be impossible to extract without damage.
The lens measures about 0.8mm thick by about 15.7mm diameter. I ordered from ebay. The sizes available were 15.5 and 16 mm and I ordered the 16 thinking I could sand it down. If I were to re-order I would get the 15.5mm to eliminate the need to sand and simple fill any difference with adhesive (duh), Weā€™ll see when the lens gets here if its worth the effort to reduce, otherwise I may re-order the 15.5mm.
The i5T is currently in active pocket rotation and the warm tint is great for night time use but Iā€™ve decided I might like 3-4K better.
edit:
ā€”ā€”ā€”ā€”ā€”-
Follow-up. I had to sand the glass down to 15.5mm for fit, but in the end during install I still managed to crack the glass. Because of press fit Iā€™m convinced that only a plastic lens will work.
After weeks (months) waiting for some things to arrive (a pack from Simon, at Convoy, and a pack from kiriba-ru), they arrived last friday.
So, I started working right away.
First thing I did was to finish a mod that I started and that went wrong some time ago: turn my Blitzwolf BW-ET1 into a 2x14500 flashlight with Anduril and 6V XHP50.2.
The story stared here and didnā€™t go well, as the LED burned (I didnā€™t use DTP MCPCB by that time).
Now, I ordered some *16mm DTP MCPCB*s from Simon and reflowed a 5000K H4-3A XHP50.2 (also from Simon) into one.
This was the final driver structure:
As for the LED, althouh I didnā€™t take photos the reflow and final soldering , I used a filed 16 x 1.5 mm old copper DTP MCPCB to help on heatsink. I put thermal paste + copper + thermal paste + MCPCB w/ the XHP50.2. I used a 5050 gasket and an+ OP reflector from the On The Road M1+ (I prefered the OP due to the tint shift that the original SMO reflector would aggravate even more).
I didnā€™t take beamshot, but it has - obviously - a shift in the beam :weary: . I will get a 3000K led to fit there :sunglasses:
Now I just need to get some longer button top 14500 cells to fit well, as the 2 button top I have are small (Sofirn 14500 900mAh) :beer:
I also received a +Convoy S6 +host from Simon and a S2/S6 triple spacer from kiriba-ru!
So, I joined these with the 17mm driver with Bistro HD OTSM from Lexel and the triple aluramic MCPCB with 3 x Luxeon V 4000K 70 CRI from led4power (that I picked as prize from the OL Contest 2019 :person_with_crown: ) and a aqua blue GITD gasket from CRX, and put this together :heart_eyes: :heart_eyes: :heart_eyes:
I only feel sorry (meaning: pissed off :person_facepalming: ) because I thought I could do a 18350 S6 as seen here and here with an Astrolux shorty tube, but it didnā€™t fit in the tail of the S6 :weary:
Actually, the tail of the S6 didnā€™t fit in any of the other Convoys I have. The head, however, and fortunately, fits in the 18350 tubes from the S2+ :partying_face: Meaning:Iā€™m not pissed off anymore :innocent:
The clip is a regular ā€œscrew-inā€ pocket clip and was ā€œflamedā€ to become more blue :sunglasses:
BTW, the spring mod was inspired in this thread/post from Bocian :+1:
BTW, this is a HOT rod!!! My go-to hot rod :smiling_imp: :sunglasses:
(Iā€™ve calibrated the temperature already, otherwise Iā€™d burn my hands :stuck_out_tongue: )
Nice work MB!
Todayā€™s mod is a work-in-progress.
I wanted to (1) test out my PIC to Attiny816 board and (2) get the recently ported Anduril for the AVR 1-series into an actual flashlight.
So I tried fitting it all together into a spare SC31B I had sitting around. Iā€™m 90% there. I have 2 outstanding things that need addressed:
  1. It seems like the MCU power is routed through a 3.0 volt LDO for some reason. So I can tell when voltage is getting really low but I canā€™t actually get a voltage reading before that. I think Iā€™m going to try and find the LDO and bypass it.
  2. The SC31B has USB charging and the status LEDs are controlled by the MCU. So I need to customize Anduril to properly react to USB charging status.
Sorry for the crappy soldering job, some of these close-quarters mods are frustrating and tedious.
To be continuedā€¦
i burned out the driver in my nitecore mh41 and since the led was damaged i ordered the cheapest xhp50 and driver combo i could find.i was posted the 5 mode driver though iirc i ordered the 3 mode. the damn thing changes mode whenever its powered on though. hereā€™s a link if anyone has any experience with it. iā€™d love to disable the strobe if i could.
https://www.aliexpress.com/item/32975900309.html
