Thanks for the review, Richie.
As a recovering flashaholic, I'm proud to say that I made it to the 5th of May before buying my first flashlight of the year.
But I definitely need this one...
I have the 3 mode, NW. Ordered on April 21.
Quality appears first rate, and it will be so convenient to be able to recharge without removing batteries. Put in three identical 18650 and these topped off quickly through the mini USB. Checked the charging output from the USB A port and this worked fine with my Nexus One phone.
My 7135s have a 35A label. Measured 2.8a, 0.8a, and 0.1 using a precision power supply.
As mentioned earlier here, there are three levels in the light pattern - the central is well defined for throw.
No complaints and pleased to employ more of my 18650 batteries.
Aloha and welcome to BLF jeober!
any PWM on the various modes with this light?
Hello and welcome to BLF, joeber! You picked up a really nice light/charger there.
It's good to have you here, jeober!
That's a very nice light. Price seems reasonable too. for what you get.
No detectable PWM on any mode
Hey Pok, if you get a chance, after you recharge your batteries inside the flashlight, can you do a voltage check on them. I'm curious to see if there is any variation between your light and mine. Charging 3 batteries, it always tops them off to 4.19v.
Mine is 4.19V too.
Thank you Pok. That's great there's a level of quality control with regard to the internals. I'd like to know what else Hanks manufacturer builds.
nice beamshots. when I buy this light I'll probably order a good diffusing lens. I like a floodier beam for camping and it'd be a shame to lose output in such a great light.
Thanks Dthrckt, if you find anything good, maybe you could post a beam shot.
Lens used here is 41.8mm by 1.85mm.
Considered a UCL lens from Flashlightlens.com but went budget and ordered a 42mm AR coated lens from intl-outdoor - $3 shipped. Maybe insignificant but fun to do anyway. Lens is very easy to access.
I saw the UCL at the other place the other day. First time I've gone there and they actually sold one in the correct diameter I could use. I wasn't sure if the extra thickness would allow the bezel to screw down all the way, but I ordered it anyway. I really don't know how much difference it'll make, but 99% transmittance sounds good to me. I'll take a beam shot before and after and see if I can tell the difference.
The 41.8mm x 1.90mm UCL from Flashlightlens.com is a perfect fit for this light. In spite of being slightly thicker, the bezel still screwed down completely. My eyes couldn't tell any difference from the non-AR coated stock lens, but I'm glad to have it installed anyway.
I really want one of these, but I don't think I can deal with the branding on that one side.
It looks really ugly...
I have to agree with you 100% on that. It was the first thing I noticed when I unwrapped it and the only thing about this light that had me skaking my head in a negative way. I haven't experimented on it yet to see if it can be removed, but one way or another, it's coming off or will at least be hidden some how.
Would you mind keeping me updated on that, anyway at all to sort that and I'll be buying one.
I also bought this wonderful flashlight. Mine is pretty "ringy" in the beam, but I can live with that. The coolest thing is the ability to charge my iPhone and iPad wherever I am. Works really well for this.
I am doing a runtime test on low. So far it has run 24 hours and down to 80% batteries according to the lights on the end.
I really love this light!
