Well worded Hikelite.
Will do some lumen measurements soon, if it didn’t had the dreadful proprietary cell, now i constantly need to charge it after doing a small test
It is actually quite convenient and standardized, saves a ton of trouble if a charging function is in such high demand.
The conflict comes at the moment when the manufacturer has fundamental issues understanding how to deliver what it wants or it could be that it is their deliberate choice to claim something then make it in such way it can’t deliver.
You need a very long spring to try that. Not recommended though.
T.b.h. a KR4 with xpl hi is probably a better choice, since the output plummets immediately.
it looks like the bezel should come off, it’s seems it’s screwed into the head, it is slightly protruding.
Get a rubber or other flat grippy surface and try to open it holding it down firmly while turning it
Got mine few minutes ago. Unprotected batteries work well If you add some coins to the negative end.
Do not use crappy batteries from bangood or etc. Flashlight works for 10 seconds in turbo then Red led flashes due to voltage drop. You will have to reinstall the battery If this happens.
Estou tentando um reembolso da Imalent sobre essa luz, apesar de todos os esforços a luz insiste em não funcionar como deveria…. mesmo com tantos videos e postagens dos problemas desse projeto a Imalent insiste em não admitir o erro nessa luz…. lamentável… Apartir de agora, Imalent nunca mais! Ganaciosos!!!
I am trying to get a refund from Imalent on this light, despite everyone who is suffering a light insist on not working as it should…. even with so many videos and posts of the problems of this project in a last case, not admitting the error in that light…. unfortunate… From now on, Imalent never again! Greedy !!!
The 3000lm “Medium II” mode throttles too (as well as High and Turbo)
From turbo, you have to go through off to get to low modes
The 21700 cell doesn’t fit in an XTAR VC4 or PBS2
The Haikelite MT09R is a triple XHP70.2 light and managed to get 25,000lm from 4 18650s. This should technically be achievable with a single 40A 21700 cell.
