Gentlemen. Maybe I am wrong. And I repeat the wrong message. In that case I apologize.
AFAIK there IS NO word for brass in Chinese. At the most it is called yellow copper
And why stating the obvious if everyone can see on the picture that it is yellow.
So what you know to be brass is most of the time just called copper.
Maybe one of you may feel the urge to add a new word to the Chinese language. Be my guest.
And while youāre at it, do bring them on speed regarding beads, bulbs and files. Have fun.
To the Chinese, as the Dutch, brass is yellow Copper, and copper is Red Copper, but I agree Chinese flashlights often dont specify, and just say ācopperā for brass.
So they do know the difference but are calling the New Ti with copper, which it isnt.
But when they are making a New AA copper, they make it of real copper, which sounds a little crazy.
The āFullā Copper Tool is indeed actual (Raw/Red) Copper. No coating, will patina.
The Ti Tool (new edition) has a brass (yellow) section in the head.
Not sure if the outer ring is actually Brass or a plated surface as on their clips and Lumintop Prince Mini...
Hi all after speaking with someone from lumintop it turns out itās not brass. It is a coated red copper piece. Looking closely at mine where the bunny is etched in thereās definitely a hint of copper showing through. Bit hard to capture on a photo as itās so shiny.
best i can do at the min to show it. If someone can rip that pic and post it would be great but im still learning my way round here and havenāt got that bit quite figured out.
probably a sharing issue, you need to set the photo share rights in your Google photoās
Sometimes BLF just cuts the link somewhere due to the length, if you insert the Link using the insert link button it might work
