[New] Lumintop Tool AA 2.0 Ti
I’ve received today “copper” pill for ToolAA and scratched the bottom. It is brass.
Thx for language explenation guys, now i’m sure that yellow copper is not possible.
:+1:
they were just “messing” w us
Is the copper yellow (brass) or red copper ?
If so, why are they using different materials?
from the photo, the AA Copper tool looks like copper not brass
I hope someone (maybe you?) will confirm, when they receive the light
copper = red copper = purple copper
brass = yellow copper = “messing”
So they do know the difference but are calling the New Ti with copper, which it isnt.
But when they are making a New AA copper, they make it of real copper, which sounds a little crazy.
Would it be a cost thing?
Well, i’ll see when they both arrive.
A group I’m on in Facebook someone’s got two coppers if I knew how to post pics on here I could pop one up.
The ‘Full’ Copper Tool is indeed actual (Raw/Red) Copper. No coating, will patina.
The Ti Tool (new edition) has a brass (yellow) section in the head.
Not sure if the outer ring is actually Brass or a plated surface as on their clips and Lumintop Prince Mini...
Does the copper head split in two parts like the ti version?
It should, Lumintop posted some photos
I really have to spare some to get those 2 lights :person_facepalming:
Nice collection! :+1:
Hi all after speaking with someone from lumintop it turns out it’s not brass. It is a coated red copper piece. Looking closely at mine where the bunny is etched in there’s definitely a hint of copper showing through. Bit hard to capture on a photo as it’s so shiny.
Hard to believe it’s copper with a coating tbh. Looks verry much like brass.
If so maybe someone is willing to polish the coating off.
best i can do at the min to show it. If someone can rip that pic and post it would be great but im still learning my way round here and haven’t got that bit quite figured out.
The link you provided is not working for me PBP, it results in error 404
The link you provided is not working for me PBP, it wants to know my Google-account.
Which I (obviously) don’t have.
probably a sharing issue, you need to set the photo share rights in your Google photo’s
Sometimes BLF just cuts the link somewhere due to the length, if you insert the Link using the insert link button it might work
Google Photos
does that work?
That works, but it is still difficult to see, the material below the lumintop engraving might be real copper
It works for me.
Looks like copper indeed, which is a pity because I like brass better for this purpose (structurally stronger, while still having good heat conductance). I ordered one (from Fasttech, they are cheap, and you can use code BLF for a bit less even) but not sure I would have done that if I knew it was copper.
Well, it’s not that you did not know, since they kept advertising with copper head :sunglasses:
