So they do know the difference but are calling the New Ti with copper, which it isnt.
But when they are making a New AA copper, they make it of real copper, which sounds a little crazy.
Hi all after speaking with someone from lumintop it turns out it’s not brass. It is a coated red copper piece. Looking closely at mine where the bunny is etched in there’s definitely a hint of copper showing through. Bit hard to capture on a photo as it’s so shiny.
best i can do at the min to show it. If someone can rip that pic and post it would be great but im still learning my way round here and haven’t got that bit quite figured out.
probably a sharing issue, you need to set the photo share rights in your Google photo’s
Sometimes BLF just cuts the link somewhere due to the length, if you insert the Link using the insert link button it might work
Looks like copper indeed, which is a pity because I like brass better for this purpose (structurally stronger, while still having good heat conductance). I ordered one (from Fasttech, they are cheap, and you can use code BLF for a bit less even) but not sure I would have done that if I knew it was copper.
