Had given it some thought. It’s a double sided dilema. Grease will trap sand and other foreign material. Having nothing should be easier to clean out, providing the moving spaces don’t wedge the particles. But the feel is not very smooth (slack).
Be very careful removing the magnetic switch as there’s a tiny spring and ball bearing underneath that’s easy to lose. The spring shot out and took me 30min to find
I guess I’m waiting for someone to disassemble the switch section of the light and show me how it’s done.
Unscrew the head. Put the light IN a towel, completely covered up. You don’t need to see the for the next step.
Note exactly how the magnetic control ring is made, so you know the front vs. back. It’s not quite symmetrical. Not SURE this is critical. I did not try it both ways. but the magnets need to align with internal sensors to work right. If you get it wrong, simply reverse the assembly position.
Slowly rotate and pull the magnetic ring toward the front. At some point the ring will clear the spring loaded ball bearing and they will pop out, both most likely. This is why you need it covered, to catch the parts.
Keep pulling and wiggling. The ring now needs to slide over the 2 O-rings behind the front threads to come off. You can remove them beforehand if you don’t want this little bit of extra resistance. Either way is fine.
That’s it.
The ring has 2 magnets in cut slots. The spring goes in the hole with the bearing on top. I DO plan to dive the light so I packed the spring hole and magnet holes with silicone grease. I’ve had some cheap dive lights like this that used low carbon steel and the spring/bearing/magnets all rusted out in a year. It’s essentially impossible to fully flush out all the saltwater from these deeply buried crevices after a dive.
Silicone grease in the spring + bearing hole helps hold it in place for assembly. Slide on the magnetic ring (remember orientation) > when it bumps up against the bearing compress the spring with a thumbnail and slide it fully on. If you don’t feel completely confident of your skill, or you have not greased the spring + bearing you might do this inside a big paper bag so they don’t get away with a slip.
Replace and lube O-rings if removed. Check for any kind of lint or debris that might compromise water tightness. Replace the head. Put in a battery and test.
One thing to note is, don’t lube the front threads of the battery tube. There’s no retaining ring giving a good connection and it relies on clean threads. Lube orings well but keep it off the threads. Had 5pcs start flickering and couldn’t figure it out for awhile.
Ended up grabbing 30pcs instead of the previously mentioned 50.
Addendum to my instructions on the magnetic ring removal. The [battery tube] @PiercingTheDarkness mentions is the long piece that the battery is installed in, NOT the front part you need to remove to take the magnetic ring off. The front threads on the battery tube are not anodized.
The part in front of that has anodized threads and you can grease it well, and probably ought to.
Great information. Thanks y’all.
Did a burn test on high in a tub of water. A 2400mA (tested, not protected) cell lasted 90+ minutes on high. At the end it started blinking for a bit, then simply went out. Seems to be an inherent low voltage cut-off. Cell measured 2,91v when checked.
Finally got mine. Very nice flashlight for the price (recent discount). It is a bummer that there’s no lockout. While the selector ring is notched, it could be rotated by accident. I don’t plan on changing the emitter. The glass has a film on the inside… but it’s more of an annoyance—I doubt it’s affecting the lumens output much. No knurling except for the control ring, so I added a bicycle inner tube segment to the body. It was tough getting it on! Took me about 30 mins while I watched a TV program. But now it has good grip while still looking nice. Looking forward to testing this while snorkeling this summer.
Above.
“” No knurling except for the control ring, so I added a bicycle inner tube segment to the body. It was tough getting it on! Took me about 30 mins while I watched a TV program. But now it has good grip while still looking nice.“”
For that, I have lotsa shrink wrap tubing of differing dia. Colour, lengths,
from Fishing rod MFG days.
Just remove head unit. tail cap. Cut and slide on the Wrap, in colour to suit.
Then warm it up with a heat torch.
Careful… Ally holds heat for loonger.
OR Self amalg tape does same job.
But tends to UNwrap from finishing end if not, (me) O,ringed down to hold.
Small overstretched O ring.
I often add a coupla small thin o rings to any torch with grooves round casing
for extra grip too. (ie S2) and early shiny C8’s.
Yes, heat shrink wrap tubing is possible, but the bicycle inner tube is more resilient & grippy, in my experience. It came out well actually. O-rings won’t hold well because of the curvature… but the bicycle inner tube is on so tight, not worried. Actually, one could cut it a little short and then use a single wrap of grip tape. The only problem with grip tape is that over time, the material will shift and expose a sticky adhesive.
For people who want some more info. YouTube is full of instruction video’s of nice young ladies who show you how to shrink wrap a banana.
And Macka17: congratulations with your birthday. Please take good care of yourself and the missus.
Thank’s Henk.
Hey all.
My 03 came Monday. I installed a Samsung 30Q. All good. works fine.
Yesterday I stripped and cleaned all 4 threads, then used w/proof grease on the 3 recommended.
Hmmm. NO Light now.
Sw rotates.
Multi on base of battery and side of case shows the 4+v. With NO show on exposed led.
Rotating sw shows voltage on each click, on batt base/case side contacts.
Changed another full charged Samsung30Q, but still no show on led.
I’m no sparky just a fiddler. Have I stuffed it somehow?
Clean the grease off the threads from the barrel, where the threads are not anodized. You may have insulated the contact surfaces.
What grease did you use, specifically? The O-rings make the seals, the grease does not. The grease facilitates screwing the surfaces together. Grease should be used sparingly. This is not a wheel bearing.
I’m still really happy with this as a general purpose flashlight. Ideal to lend to people who’d be baffled by BLF-type user interfaces.
And I have to say I even get lost in the multiple-click UIs myself every few weeks and have to pull out the printed instructions.
This simple clickstop ring for three brightness settings is soooo simple.
Now I gotta mod an amber LED into it ….
Yes BUT you have to remember which way you rotate it. It is a weakness and a strength in that the ring will rotate either way with no stops. If you turn it one way it’s on low, the other way it’s on high and since you forgot which way to turn it but you wanted low, your night vision is now toast. But you can start on high or low, as long as you remember which way to turn it:-)
Great light, still loving it! Sadly it appears that Sofirn discontinued it.
As a diving light I don’t think divers would care their night vision in the water, most always want the brightest setting.
The SD03 isn’t as good as you think. As a dealer I purchased 45pcs and have had nothing but trouble. The threads at both ends are all that make a connection, there’s no retaining rings on this model. Continuously you remove the tail cap for batteries and it becomes very dirty causing a connection problem. I’ve had to clean all the threads with electrical cleaner before selling to stop the light flickering, spent around 10 hrs cleaning, sometimes multiple times to get a reliable connection, had to sell for near cost to get rid of them
Wow, no issues with mine. I leave it by the back door at our coast place to check for critters nightly when I let the dog out. A paint lid will rust in a week down there if left outside and I see nothing wrong with the light.
I haven’t had any returns, but to get them working properly they needed a thorough clean. I have a 30 x 30cm microfiber cloth black from how dirty the threads were.
I reckon I received old stock that perhaps had been sitting for awhile.
My SD03 has started blinking with fully charged batteries. Any help?
