After weeks (months) waiting for some things to arrive (a pack from Simon, at Convoy, and a pack from kiriba-ru), they arrived last friday.
So, I started working right away.
First thing I did was to finish a mod that I started and that went wrong some time ago: turn my Blitzwolf BW-ET1 into a 2x14500 flashlight with Anduril and 6V XHP50.2.
The story stared here and didnāt go well, as the LED burned (I didnāt use DTP MCPCB by that time).
Now, I ordered some *16mm DTP MCPCB*s from Simon and reflowed a 5000K H4-3A XHP50.2 (also from Simon) into one.
This was the final driver structure:
As for the LED, althouh I didnāt take photos the reflow and final soldering , I used a filed 16 x 1.5 mm old copper DTP MCPCB to help on heatsink. I put thermal paste + copper + thermal paste + MCPCB w/ the XHP50.2. I used a 5050 gasket and an+ OP reflector from the On The Road M1+ (I prefered the OP due to the tint shift that the original SMO reflector would aggravate even more).
I didnāt take beamshot, but it has - obviously - a shift in the beam . I will get a 3000K led to fit there
Now I just need to get some longer button top 14500 cells to fit well, as the 2 button top I have are small (Sofirn 14500 900mAh)
I also received a +Convoy S6 +host from Simon and a S2/S6 triple spacer from kiriba-ru!
So, I joined these with the 17mm driver with Bistro HD OTSM from Lexel and the triple aluramic MCPCB with 3 x Luxeon V 4000K 70 CRI from led4power (that I picked as prize from the OL Contest 2019 ) and a aqua blue GITD gasket from CRX, and put this together
I only feel sorry (meaning: pissed off ) because I thought I could do a 18350 S6 as seen here and here with an Astrolux shorty tube, but it didnāt fit in the tail of the S6
Actually, the tail of the S6 didnāt fit in any of the other Convoys I have. The head, however, and fortunately, fits in the 18350 tubes from the S2+ Meaning:Iām not pissed off anymore
The clip is a regular āscrew-inā pocket clip and was āflamedā to become more blue
BTW, the spring mod was inspired in this thread/post from Bocian
BTW, this is a HOT rod!!! My go-to hot rod
(Iāve calibrated the temperature already, otherwise Iād burn my hands )
