Wow, that’s like letting your own kids sit at home playing with wrapping paper while you take the neighbor’s kids to the park.
I didn't even follow the link.
Do I think you're an obvious spammer?
Ewww, they suck! I wouldn’t even let a crack-ho wear one of those shirts. :confounded:
So what’s the deal with OSRAM LED emitters? I’ve seen some growing enthusiasm for them. Looks like at least some models are ideal for throw. Are there any current production flashlights OSRAM emitters worth considering with ?
That’s precisely the case - there are several LEDs that throw significantly better than any other LEDs which understandably causes a lot of enthusiasm.
I can’t help myself…
Lowani under two moons.
Sokath! His eyes uncovered!
And for something completely different.
Lord knows what nether regions yon digit has erstwhile probed.
Thanks for the link! I’m looking forward to seeing how these progress. Are there any production hosts using them with notable success?
Here is a stupid question. ” If a XHP 70.2 led is tested for lumen output here on BLF to 8.5K lumens @ 12v and 8 amps ( not sure if accurate ), Can a big flashlight like the GT check 10.5K lumens ” ??
I am trying to verify a lumen tube for accuracy.
Any help is appreciated.
Any help is appreciated. :question:
It all depends on the tube and its calibration. Some people have gotten 8.5K, but it was not with Maukka calibrated reference sources. It is very hard to find the right calibration. Depending on your calibration you can make it whatever output you want.
With my 6 volt Convoy L6 with Lexel FET and P1 bin 5700K xhp70.2 with Aspire 4300mah cells it pulled 19.6 amp / 5500 lumen at 1 second and 18.4 amp / 5250 lumen at 20 seconds. This is out the front which includes losses from the reflector and lens.
With a bigger light like the GT you go from 2 x 26650 to 8 x 18650 so it can pull a bit more amperage due to less voltage sag. Instead of 19 amp it can in theory do 21 or 22 amps. Because the output curve of the 70.2 as nearly maxed out, you only see a tiny bit more of output.
So it’s possible to get more output. Especially between a med size light and a big light. For example if my L6 drew 15A and a GT drew 19A. Then you might see a bigger jump in output.
As far as calibrating a Lumen Tube, you need a proper reference source. Every Led varies in output even with the same bin and you don’t always know the details of how it was measured in the first place.
So based on a Maukka calibration source, your 8.5K and 10.5K are way too high. Even for a raw led.
Thanks for the explanation JasonWW.
I also have Maukka calibrated lights and 3 different lumen tubes. The problem I’m having is with big lights that are reading low in all 3.
For example I tested a MT09R at 29.8 amps in a 6 inch tube calibrated with Maukka calibrated lights it checked 14500 lumens. Should that number be around 22K to 25K ? it will burn paper and it has a TA driver.
My 8 inch lumen tube is calibrated with a MT07S with a xhp 35 HI @ 2700 lumens. It reads 24K lumens on the MT09R but also gives 9800 lumens on another light that should be around 8600 lumens. The 6 inch tube is ok for less than 2K from what I’m seeing. Maybe the various beam patterns is the problem.
I still think your numbers are low. ~20A in 6V XHP70.2 should be getting close to 7000 lumens, especially on a cold start. There are losses for “OTF lumens” but I wouldn’t expect it to be over 15%
According to who? Why do you think this?
I think most OTF losses are between 25 and 35 percent.
My 8 inch lumen tube is calibrated with a MT07S with a xhp 35 HI @ 2700 lumens. It reads 24K lumens on the MT09R but also gives 9800 lumens on another light that should be around 8600 lumens. The 6 inch tube is ok for less than 2K from what I’m seeing. Maybe the various beam patterns is the problem. :weary:
You should ask TA. He tested these same lights so he has a good database.
Maybe it is related to the Lumen Tube diameter? I have the small Tube. If I had a bigger diameter maybe the higher output lights would read differently? Maybe Maukka needs a higher output calibration light to sell?
All the professionals use large integrating spheres. This is the standard. There could be flaws in the idea of using a Lumen Tube. Maybe the use of 3 diffussion sheets is too many or not enough? Maybe the beam shape does influence the output? IDK. The tubes are way cheaper to build and seem to do a pretty good job.
I considered building a 1 meter sphere to test lights in, but it’s expensive, takes up a lot of space and I’m not that interested. I would not put all my faith in lumen numbers. Also, some people’s numbers I trust more than others. Amp draws are still a pretty good reference point in my opinion.
Considering all specifications & performance, which flashlight would you choose & why?
- Lumintop GT Mini Pro XHP50.2 (1)
* 3500 Lumens, 480m throw
* 18350 or 18650 battery
* NarsilM
* Cost: $49.95
- Lumintop FW21 Pro XHP50.2 (3)
* 100000 Lumens, 325m throw
* Anduril
* 18650 or 21700 battery
* Cost: $69.95
Choose what works best for your needs.
* NarsilM
* Cost: $49.95
* 10000-0- Lumens, 325m throw
* Anduril
* Cost: $69.95
Neither. Not a fan of XHP50.2. It’s better suited to GT Mini, but I’ve disliked the GT Mini somewhat ever since it was released. It was a silly play off the BLF GT’s popularity, a poor man’s D1S, and not even an aesthetically pleasing light (to me).
But I see why it gets used. It’s the easiest way to put the biggest lumen numbers possible on a light. Just slap a FET and 3V XHP50.2 in everything. Nevermind the atrocious beam quality, floody nature, rapid temperature throttling, etc. It’s worse than when we started throwing SST-40s in lights and calling it a thrower LED. Like what? A domed 5050 LED? And then it was getting thrown behind FET drivers (because, again, cheap) where it’ll draw way more power than it needs to. The optimum was something like 6-7A and an efficient regulated driver around there would’ve been awesome.
Sorry for the rant. If you said I had to use it, I’d pick the GT Mini. The throw will be way more usable - the “325m” on the FW21 Pro is only at max lumens, which is only sustainable for like 5 seconds before your fingers blister. So you’d end up singeing your fingernails every time you needed to see the other side of a parking lot. But if you were going to force me to accept one as a gift, I’d say the FW21 Pro, so I could sell it.
Thank you! This is useful info. I’m not well schooled on the XHP50.2. I thought the beam pattern looked OK from photos & video, as well as the flood. But rapid temperature throttling was not covered in those. So this light essentially becomes a firecracker. It goes off. Loud bang of light, but then… it can’t handle it & must step down. So all that fanfare for nothing. I guess there’s a reason why something like the BLF GT90 has active cooling. The Mini has too focused a hotspot, while the Mini Pro looks a little better. But still… it pales in comparison to the big brother.
In terms of the size class I covered in the listing above, I’m thinking an Emisar D4SV2 would be a better candidate.
What LED emitter do you favor for a good combination of throw and spill? Are you a fan of the latest OSRAM emitters?
