Don't get those. One person on the other forum measured some cheap ones from ebay and they were all over the place in their quality. The highest was about 700 mah all the way down to 150 mah.
Cheap batteries are not worth it. Most of the garbage gets unloaded for a cheap price simply becasue they are either faulty, defective, shoddy or unsafe. Returns, remanufactured and possibly DOA. Usually if you buy this garbage, you'll end up spending more in the long run simply becasue cheap batts will not have the duty cycle required to be economical. You'll charge them a few times and then their done. The will never be rated at what is advertised and some of them will burn out your house or damage your charger.
Places like http://www.easylightbuy.com/ have less expensive batteries but are good quality. Everything I've purchased from them has been as advertised, new and up to spec. They have Trustfire batteries for a lot less than most of the other places. Sometimes as much as 50% lesss. They also ship pretty fast. My last order only took 14 days to receive.
I only support places that repeatedly carry good merchandise at fair prices. I don't want to give my money to the Chinese Money Whores who would sell anything ( crap).
I want to support only the good guys, even if they are outside the U.S.
They are for a skyray king and some other random 18650 lights I have. I will check out easy light buy. I haven't heard much of them. Sounds like one of the sites that the spammers are always spamming about.
The best budget bang for your bucks from a trusted vendor is probably HKequipment.net
They have the good ultrafire 3000 mAh (2600 actual) batteries in a 4 pack for around 31 usd or you can write them and hear what price they can ships them out for if you buy 8 or more (which it sounds like you may need).
That being said think that personally I may have to go for the 3100 mAh rated xtar batteries they have when next I need some. I am tired of getting random batteries of varying quality. I have bought from CNQG (no good - 2 arrived DOA but they were quick to respond to RMA and send 2 new free of charge - but they perform about 65% of the DX 3000 mAh ultrafire ones i have so I wont go there again)
I have some that were delivered with lights as part of the package but those generally suck. Have 2 good ones though but dont remember from which vendor/package I got them.
As for checking this yourself try this method: If you have a battery description you trust (mAh rating etc) then take the price of 1 battery and divide it with the Ah rating. Like the 3100 mAh rated xtar batts:
Thanks for the responses. I think I'm going to try my luck with easy light buy. I will probably get the flames since the price is better than anywhere else and I haven't had trouble with them before. Are any of their $5 batteries any good?
Because it seams a lot of people recommend batteries on here with out any actual testing and run time test do not really show true capacity.
I have personally tested 18 to 20 of these over near on 10 months now. They all test to 2400 to 2500 mAh and the protection work's, the PCB has two (IC'S) mosfets so they will handle 3 to 3.5 amp draw no problem.
I do not trust DD, DX and Ebay for genuine trustfire flame batteries !
+111111111!!!!!!
Please listen to benckie on this. Only the Trustfire from Manafont has been tested with positive results. Apparently people don't understand how easy it is to shrink a fake wrapper on an old cell and call it whatever you want. Fake TF cells have been found at DX, DD and many eBay sellers. Why take a chance to save a few bucks? TF 2400 might be $3.19 at Easylightbuy, but it also might be 600mAh in real capacity. You don't know until it is tested.
Pfft... hahaha... I have got everyone beat. 4pcs Blue UF 18650 from BuyInCoins, $3.20/pair, tested 51, 2, 3, and 18 mAh! Yes that was no mistake, TWO friggin mAh!
Granted I got most of my money back and 5% discount card, but bottom line is, don't buy these cheap batteries, especially from BIC! Well, I don't mean boycott BIC altogether, their price, shipping and CS is great, just skip their lame batteries.
Well I don't have the equipment to test for true MAH, but what I do know is all the Trustfire Flames I have got off ebay so far have been what I call very good batteries. I have bought some from Manafont as well. I can't say I can see the difference but then again I don't know which ones are actually from Manafont anymore.
I do appreciate benckie taking the time to test though. His test is why I mainly just buy the Trustfire flames now.
+111111111!!!!!!
About TF's & Manafont...
First batch of Trustfire "Flame 3000" was good, after that, pretty much no-go price/quality wise.
You really don't know, until YOU test YOUR specific battery, one by one. DX, DD etc. have got the same lottery from all of them with TF's.
Spend 14$ / pair, get Xtars. Current count is maybe 20, not a single dud.
Fair enough, Cheap Thrills, but benckie has tested 18-20 TF 3000 flames from Manafontwith consistent performance results. They seem to be the only one that sells a consistent product.
I agree with you on the Xtars - great cells, but they do have a problem fitting in some lights, as do Hi-Max, which is another good testing brand.
Hmm, sounds like I may have missed some thread now? Or just forgetting something...
Anyway, I got two pairs from there. Both alike. First with higher capacity and way higher Amp output and the second not even on-par with best
Dino-Lottery TF 2400's...
edit, correction: got first ONE good pair, after that, TWO bad pairs.
Check a couple of posts below. Most astonishing thing was, they could not deliver more than 3 Amps even with a full charge and direct drive light (First pair was over 4A!!).
edit: and yes, the first pair was GREAT replacement for a bit too long Xtars. I was an idiot selling that pair away with STL-V2
Are there any domestic sellers where I could get these and pay a bit more, but know they are genuine?
I am not anywhere near the level of being able to test them on my own.
“"A free people ought not only be armed and disciplined, but they should have sufficient arms and ammunition to maintain a status of independence from any who might attempt to abuse them, which would include their own government.”” -George Washington
Sad that even the tiny blue TF 10440, crappy that they were, beat the pulp out of the 18650 blue UF.
These are ALL from BIC. I honestly give you guy a heads up, skip these, a little extra will give you a LOT more for your money. Try to stay with Manafont for budget batteries, though not perfect, but still at least have a bit of quality control.
Not really. If you're willing to use unprotected then you can harvest them from laptop batteries.
My LED comparison thread with links.
Tint, Binning, and CRI Explanation (For the XM-L)
http://budgetlightforum.com/node
I saw some on ebay. But I know that's just asking for trouble.
Lowest you can go is pair of blue "2500mAh" (actually 2200mAh) TrustFire's for $8/pair.
Welp. What are the cheapest you would recommend? (edit: Oops question answered.)
http://www.kaidomain.com/product/details.S009747 these ones if you don't need protection.
I do need protection. And I may be 8 or more. That's why I'm very concerned about price.
What are putting these in that you need 8?
On DX
Mine have 1900mAh.
~ Zeroed4x
Just buy the protected Trustfire flames either on ebay or from Deal Xtreme.
http://www.dealextreme.com/p/trustfire-protected-18650-3-7v-true-2400mah-rechargeable-lithium-batteries-2-pack-20392
My flashlight collection
http://budgetlightforum.com/node/10711#comment-183257
http
Or you could pay less at Easy Light Buy
http://www.easylightbuy.com/trustfire-tf18650-2400mah-37v-protected-liio...
Real Trustfire 2400 mah Flames for $3 less than DX. I've bought them, they are the real thing, not re-branded, not fakes.
They are $6.38 for a two pack and not $9.38
~ Zeroed4x
~ Ledsmoke ~
Dutch humor:
[quote=djozz]
I do not think that the BLF-community ben
NOOOOOOOOoooooooooooooo. and i just got another pair from DX. =(
Marky Mark
Have you guys tested the true mAh of them ?
Original?
These or these?
Both !
Protected TrustFire 18650 3.7V 2400mAh Rechargeable Batteries - Flame (2pcs/set
+111111111!!!!!!
http
Fair enough, Cheap Thrills, but benckie has tested 18-20 TF 3000 flames from Manafont with consistent performance results. They seem to be the only one that sells a consistent product.
I add here some links, some other people also have had not so good results:
http://budgetlightforum.com/node/7000#comment-133761
http://budgetlightforum.com/node/7000?page=1#comment-141319
Here's the cap for my first pair:
http://budgetlightforum.com/node/4741#comment-104879
...and here for the second 2x pair:
http://budgetlightforum.com/node/7566#comment-151375
-George Washington
Seems to me that Xtar had some problems with their batteries if I read correctly but I don't remember what was said.
http
I have bought quite a few Trustfire flames from BIC on ebay and I have to say they all seem good to me and perform well in my lights.
http
My results from BIC batteries, discharged at 1A:
Blue UF 18650 (2400mAh): 2 - 51 mAh
Blue TF 14500 (900mAh): 270 - 350 mAh
Blue TF 10440 (600mAh): 170 - 180mAh
