The goods news is that this light is planned to come with an overhead headstrap, as far as Mark told me today. This overhead part should give more support for weight balancing and distribution. For reference, a headstrap comparable to this one...
Acebeam's H30 is also quite heavy and big in size but I don't know how well their sales were running for this light. Did many people complain about PL47's weight? What headstrap did Fireflies supply with the PL47? Maybe we can use some best practice here to get a better product. ;-)
I hope Mark or I will soon be able to get to tell the interesting specs about the driver. What I was told so far...
Type C charging unit incl. reverse charging (= "powerbank feature")
Sofirn's in 2019 revised ATR (advanced thermal regulation) with a 50°C threshold
Please note that the UI is still work in progress. Mark and I have talked a lot today on how to improve the UI for more convenience and flexibility. My plan was to remove the entire strobe modes (I hope everyone here agrees to this point of view) as strobe modes are proven to be quite ineffective against assaults by human beings or animals and often considered as a nuisance in BLF flashlights, especially in a headlamp. However... there are reasons to keep strobe modes and so my suggestion was to put strobe modes in a hidden section of the UI and leave more room for direct access to turbo mode from ON and OFF. We also try to improve the access to moonlight without getting into conflict with the nice powerbank feature while reverse-charging an external device.
I thought the PL47 was completely useless as a headlamp. I have one, the original, and use it more like an EDC. I recall lots of criticisms. Funny, the Amutorch E3 is very light for a 21700 light, but of course it's not a right angle head.
Yes, if strobe is no need , ad the most important is that access to instant moonlight and turbo, we will probably give up all strobes modes ( strobe, SOS, beacon)
My opinion concerning headlamps (and flashlights) used for hiking, camping, mountaineering and other remote outdoor activities:
1) The SOS mode would be useful in case of an emergency.
2) The beacon mode would be useful to help someone find their way back to camp or another location.
3) The SOS and beacon modes should be able to last a very long time without draining the battery too fast.
4) The magnetic tail cap should be an optional accessory or have a way to add or remove the magnet in the same tail cap.
Problems created by magnets:
a) They alter the reading and accuracy of a compass even from quite a distance away, so the compass cannot be used to find the correct direction of travel or take a bearing or accurately orient a paper map.
b) They erase the magnetic strips on credit cards when they get too close, so they cannot safely be near a wallet or in the same bag as a wallet.
Agreed! That makes sense. As long as these modes do not appear in the default stepped mode order, this should be fine. For instance, I could imagine activating SOS or Beacon mode i.a.w. the given UI like this:
When the headlamp is ON:
3x click = Turbo mode (both LEDs at full power)
from Turbo 2x click = SOS strobe
from SOS another 2x click = Beacon mode
from Turbo/SOS/Beacon 1x click = return to previous standard mode
When the headlamp is OFF:
Long press = Check battery status (will also work while reverse charging or while locked out)
1x click = turn ON (unless locked)
2x click = Moonlight/Firefly mode (0.5lm) (will also work while reverse charging or while locked out)
Since headlamps and flashlights are uni-directional, a "diffuser" accessory would help the SOS or beacon signal to be visible in all directions even though the light level would be less (but at least you would have that option and the diffuser could also be useful in camp, but I realize it is not as easy to design a diffuser for a headlamp as it is for a flashlight).
Yes, but it will probably get more difficult to diffuse the light evenly in a 90° angle headlamp beam than in a standard flashlight which emits light vertically upwards into a diffuser cap (attached to the head).
If you want something universal for usage both as headlamp and lantern (with diffuser cap), the head would need to have an adjustable angle.
The Astrolux HL01 (in 18650 format) weighs even heavier than the Fireflies PL47, so I think that’s one downside of the HL01…
I’ve also gotten the PL47 (Nichia 219B very nice tint), but as Tom E mentions, use it mostly as a flashlight rather than in headlamp format…
I suppose headlamps will really have a weight limit to be useful (and not feel too heavy)…
I‘m not against having strobe modes included but I guess the majority here will agree to have them hidden in the UI to prevent accidental activation. Strobe modes are often advertised to drive away / disorientate people or animals assaulting oneself. This has been more or less proven to be quite ineffective. However, to catch someone else’s attention as illustrated above, I agree that SOS and Beacon can be useful.
If you are lucky you will never need SOS, beacon, or strobe as an emergency signal.
But if you are not lucky, it is very valuable to have all three of these features as they each provide a unique capability for very different situations.
It would be helpful to have some hints in the instruction manual so people can better understand when to use these features because while most people know what SOS is for, many have never used a beacon or realize how visible a strobe would be during daylight hours.
I tried to tweak the UI a little bit, put a bit more emphasis on accessing Moonlight and Turbo mode more easily as well as keeping strobe modes available but hidden. I hope this chart is easy to follow. Any feedback is welcome. THX.
