I had the same problem with Excel.
I ended up adding a column starting at 0, and progressing at the sample interval. Using that as a time scale.
I like Libra Calc for the graphs, but could never get the darn thing to put a time scale on the graph correctly. It seemed to have a mind of it’s own as far as making the time interval on the axis.
But other than that, it worked well and is free.
I have been using one of the osram diodes that seem to be inside all of the reasonable cost lux meters.
In one of the circuits from Terry’s vast diode test. They are quite cheap.
I measure with PICO-Log software. But that’s not a stand alone option.
All the Best,
Jeff
I have the strange feeling that they might actually (close to) be the same as the Extech SDL series.
Alghough the buttons are placed differently, the rest looks pretty similiar.
This looks like a very interesting meter, it can record 2000 data points with a selectable interval, and its cheap, so it might be useful.
It has bluetooth and usb (for retrieving only probably)
I’ve added a short post with a bit of information about what I ended up doing. It works great for me, and I’ll keep working on it to clean it up if there’s interest.
Thanks bmengineer! It’s pretty basic but it’s great having immediate visual feedback. It also displays the IP address at start up (despite using a reserved IP) and diagnostics in case any sensors aren’t detected.
Instead of using an app or a batch script to log the readings, the ESP8266 itself is hosting a webpage that you pull up. That way you can use your phone, a tablet, or a computer to perform tests. And instead of polling data at set intervals, this keeps an open socket connection that quickly pushes new data any time there’s a sufficient change in the data. Oh, and I added a real-time graph.
