For $5, why not? VOKKA 1000-Lumen Small Flashlight, CREE/OSRAM Dual-LEDs, 5 Modes, IP65 Water-Resistant, Rechargeable Handheld Flashlight with Tactical Silent Button, for Dog-Walking, Camping, Hiking, Emergencies https://www.amazon.com/dp/B07PPB3NRH/ref=cm_sw_r_other_apa_i_ZhT5EbMDTNRGN
Anyone wanna take one for the team?
I’m in for one .
I'll pass because it has disco modes that I think one cannot easily avoid.
It might be good for modders, though.
Wellp, my thinking is that the driver (with onboard charging) is pretty much married to the host, plus it looks like it’s even a driver-in-tailcap design, ie, no mention of having to have the light turned on to charge, in either the description or reviews. And if some putz is returning the light because it doesn’t come with a Crapfire cell even though it says that pretty clearly in the description, you know someone’d be returning it for “not charging”.
And no mention how to switch between flood and throw?
Dunno, sounds like Hell to mod, and worse to keep as-is.
Intriguing idea, though.
I've had too many $5 shots of Vokka already .
Ordered. For $5, worth just to take a look at the driver design.
Yes, that is most unfortunate and why I couldn’t bring myself to pay the usual $35 for one, but being as I have a specific albeit seldom use for a small 3000k high cri light, I can deal with the $18 and change it ended up costing.
I did see it claimed somewhere that 14250 batteries can be used with a spacer. Do you know if this is true?
Vokka Vokka Vokka I would give it a try if I could tell that both emitters on/off controlled separately. Both on at same time??
The C2 is really nice love the E21A but that darn weird battery is impossible to source without ordering in bulk from China.
Vokka coming tomorrow, I’ll let you know
Ordered
Sounds like Fozzy Bear!
Or Fonzi bear.
Ayyyyyyyyyyyyyyyyyyy.
Got my Vokka today. The finish feels good with no sharp edges or visible blemishes. The battery tube is about the diameter and length of a 26650 and has a lot of extra space inside for an 18650 to rattle around, but the springs seem strong enough to prevent it from happening despite a few vigorous attempts. Although there is a tail clicky, it does not completely turn off the light as half presses still turn it on no matter how many clicks you try and no tailcap lockout. USB charging seems to work, nothing special and hopefully it doesn’t compromise water resistance. Brightness seems better than average for a $5 flashlight today. With both LEDs on, the hotspot is not as bright as my Convoy C8, but it is much larger and probably more useful for general use. The color temperature seems to be pleasant, not too cool or warm, I’d guess in the 4k to 5k range. Overall it seems to be a good deal at this price, as long as the parasitic draw doesn’t prematurely kill the battery due to not having a true off or lockout.
KuoH
If you need to light up your backyard vipon has a coupon for the Led motion sensor light going again for $13.99.
https://www.vipon.com/product/7516868-Motion-Sensor-Lights-AmeriTop-35W-Ultra-amazon-coupons?
https://www.amazon.com/AmeriTop-Sensitivity-Illumination-Certified-Waterproof/dp/B07KMK8X3K
I got one the last time they ran the deal and its bright with adjustable beam. The add says 3500 lumen and I’d have to say that’s pretty close.
Similar output to a Q8, I used it to light up (Driveway and parking area) my sons basketball court.
I wouldn’t buy it just to replace a outside light unless you need to light everything, its bright.
Out of curiosity, got one of each.
The A7P works fine. Looks like a decent enough light.
The A3N is a lemon. Something’s definitely wrong with the switch, doesn’t switch modes reliably, can’t even turn the f’n thing off!
Great, sitting untouched, it just magically turned itself on again.
Guess I’ll be returning this one… :confounded:
Well heck, sorry to hear that. If you unscrew the section behind the clip it will expose the switch and you can try the switch without the rubber cover or silver button potentially interfering.
Possibly use some fine tweezers to make sure the driver is in firmly and the switch as well. Can’t be much more than that?
Or do what non-flashoholic people do: send it back and have a new one sent!
Yeh, I found out the hard way trying to stick in the cells that the tail only covers the switch end.
After it went mental, that’s the first thing I did, got rid of the interference and tried bapping the nekkid button. Still no joy.
So yeah, already put in for a return, Mr Oops is gonna pick it up tomorry.
Oh yeh, the other one’s nice. Makes a better vampyre than a 1×AAA light. Tossed in some dead cells, still lit up with rather decent brightness whereas my Wuben/Ultratac 1×AAA lights wouldn’t even turn on.
Thanks for the heads up . They are a kick arse light. Bought a 2nd one just for future use.
