Just for the record, Liionwholesale claims that some recent batches of the 30Q might have weird can markings due to temporary production facility changes. I have a few marked making me think they were 29E’s as well but they have similar IR and capacity to my known legit 30Qs with good can markings.
Sooooo I just realized my two latest batches from Lucky’s Electronics Store on AliExpress sent me 30Qs with the top line of code “L30Q” . This has been my trusted supplier for the last 4 years and is listed on BLF as a trusted source.
I’m just charging a couple up to do a discharge test on my CBA.
I had 100pcs with an added button top arrive genuine but looks like my flat top are fakes.
Genuine always test at 3.40v and these read 3.44v.
EDIT: Well, they’re genuine. Tested at 15A and got 2968mAh and it almost perfectly matches the curve of Mooch’s test back in 2018
Just starting fairly recently, I’ve started to record measurements of batteries (from shipped condition: voltage & IR as tested with YR1030 resistance tester, and weight; I haven’t started doing measuring dimensions though).
So far the genuine 30Qs I get arrive usually from around 3.36v-3.45v. and there seem to be 2 sets of IR readings, I think both are genuine.
1 set of 30Qs (“141”) have YR1030 IR reading of around 11.8-12.0mOhms, while the others (“136” and “138”) usually around 12.6-12.8mOhms.
I have the same resistance tester as you and two cells with L30Q read 12.06 & 12.11. It’s very interesting that these are genuine when Mooch said if it hasn’t got “0” as the 2nd digit it’s fake
One online shop in my country has a good deal of 30Q (around $4.5 per piece). But the close-up picture shows a faint code R30Q/JCKA6 (I think). It is neither “0” at the 2nd position nor “L30Q”. In addition, some VTC6 pics in this shop show LiitoKala sticker on the cell (I heard a lot of fakes in Liito store).
I’m not sure whether to buy from this shop or not. I also don’t have tools for testing, so buying and testing it is not possible now.
Additional reference, this is the picture of markings on pink wrap.
$4.50 a pc sounds pretty cheap though but if he’s buying in massive bulk then they’d get a better discount than me. My cost price is $4.40 usd excl shipping.
Goatlvl, the top or positive pole of cells is a distinctive trait. Battery brands carefully choose the geometry and shape of the top pole for their cells. Its like an emblem, unique. Different brands never (!) use the same top / positive pole. This is the shape of the Samsung one:
Just my guess I searched hi and low on internet and never found any confirmed legit that had 3s like that. But, that was mebbee 2 years ago so who knows now. Mine with rounded 3s were fake. Genuine ones from Illumn later were slanted 3s.
… Thanks. This might cut out some possibility of fake. But this shop replied me that they source from many places :person_facepalming: .
… Thanks. This sounds good easy check point.
Firstly, I thought it is fake. But I’m not sure now because another bigger good-looking shop authorized by Vapcell (and selling 30Q a bit more expensive) also has same “3” on pink wrapping. Unfortunately this shop refuses to take pictures of actual products for checking. In fact, AliExpress’s Vapcell Store shows this “3” too.
I think I’ll just have to buy one and check top as Barkuti said.
At least other buyers gave good feedback. Even they are fake, they should perform good and are cheaper than the Vapcell branded batteries.
I never thought finding a legit 30Q would be thid difficult :weary: .
Can you please tell me how you or others found out they were fakes? Did you/they strip them or pentest them? I have recently ordered some of these but now that they are on backorder...
I understood that 30Q6-T is Chinese made. Is this marking applied to other 30Qs as well (Korean made and Malasian made)?
In addition, that button top in your pictures, can I just assembly the metal cap and insulation pad (maybe with or without glue) then wrap them up without soldering?
