Charging mode only reports how much it puts into the battery. If you want to check that use the Cap Test mode. Do note there is an issue with this charger in that mode where it won’t really fully recharge NiMH cells at the end of the test despite it saying they are 100%. I just do a Charge mode on any cell right after the Cap Test is done.
Take the milli-ohm values with a grain of salt but higher numbers generally aren’t a good indicator of battery health.
Li-ion cells have a nominal voltage of 3.6V while NiMH cells are 1.2V — so they are completely different and not simply interchangeable! You really should do some research…
I have some older low self discharge cells that no longer can even handle just a 250mA discharge rate, but I can still use them in some of my LED flashlights. For some flashlights I use 3AA-to-D parallel adapters to make use of my older cells.
I charged many batteries and on two of them the charger was filling the battery much more (4000 mAh) than the theorical capacity (2700 mAh). The battery was very hot when I removed it from thé charger… I think this very dangerous !
I can’t charge battery on night or when I’m at work, I’m not very confident …
I have noted a similar behavior (both on this charger and my old LaCrosse BC-900) with old worn-out batteries. Maybe try the Cap Test or Repair function on those cells.
Not a problem; I’m really looking for a multi-slot high current tester. Let the cooling be handled by me.
Most testers I generally found are .5A on discharge test which is utterly useless for any high current cell.
Opuses can do 1A on all slots (and needs modded cooling). Did not find anything better so far.
I bought this charger 2 weeks ago and have put it through its paces. My impression thus far is it does very well. Appears to be accurate. Build quality is “ok”. About standard for the course. My ONLY issue is the power supply. It is noisy. I can hear a constant buzz when not plugged into the charger and when plugged in and charging a cell you can hear a pulsing sound. Not good. Almost too noisy to share my office. I might have to start looking for a quality 12V 5.0A = 60 Watt charger that is quite as this buzzing is problematic for me. Anyone know where I can buy a decent build power supply?
@tatasal
Got this charger less than a year ago and it worked great for my needs.
The other day went to charge some batteries and the screen was blank.
Long story short I am looking for a new charger since this one is dead.
Sent email and pm to Neal however got no response if it is covered under warranty.
I received my s4plus today.I can't change current. I do what instructions say. Charger says its in 3a current but then goes down to 157ma. Seems like Charger doesn't go into manaul. Can anyone please help. Thanks Jim
Set to Manual mode while there is no cell in the bay.
Once a cell/s is loaded while in Manual mode, the charger’s “mA” in the Display should blink, then you can press the “current” button to the mA you wish.
I don’t think there is currently a commercial charger/analyzer that can consistently show the correct IR each time, not even my more expensive SkyRC MC3000, considering the inherent drawbacks of using “sliding” rails in order to fit various kinds of cells in the bay, tightness of the contact points, etc., etc. that can affect such IR readings, though they can be just about in the ball-park figure and of course, better than no reading at all of the old analyzers that we have.
….and these manufacturers actually never claim that their product can consistently give the correct reading, each time.
However this is the Vapcell IR tester that I have that can “repeatedly” give out the same IR figure almost each time:
thank you
I need education, considering my first analyzing charger
I have noticed that my old Eneloop, no longer produce as many lumens from my AAA Tool, as my new Eneloop. Im not sure if that is due to IR, or loss of Capacity, or something else
is this S4 a good charger for me to monitor the capacity and resistance (at least to tell new cells from old ones), of my aging Eneloops, as well as LiIon cells?
or would you suggest a different analyzing charger, for my application?
