Not an official answer at all but my personal interpretation:
Andúril would probably need to be configured to the driver's characteristics (e.g. it needs to fit to the corresponding MCU, NTP sensor), its thermal calibration needs to be properly carried out from factory in order to work as intended.
Moreover, Sofirn/Wurkkos would need someone with in-depth expertise to have Andúril tailored to HD20. I don't know how much time someone like ToyKeeper or anyone else familiar with FSM is able and willing to spend for this important task. Lately, my impression on BLF is that more and more manufacturers - small or big ones - get interested in selling their lights with Andúril UI. This trend will inevitably lead to a situation of delays in UI development with only a handful of coders/programmers experienced with FSM.
Last but not least, you already named a quite important term..."a selling point to everyone familiar with it". As much as I like Andúril and all of its features, it takes a considerable learning curve to understand and memorize all of its great features. Now, let's just switch for a moment from the customer's point of view to the seller's point of view. If your customer service team gets a ton of questions asked from inexperienced users who just refuse to read the manual (for whatever reasons), you need to have well-trained employees familiar with Andúril and probably a significantly higher headcount. If customers return their lights in large amounts due to misinterpretation of the UI (e.g. being trapped somewhere in the UI), sales managers may reconsider using a complex UI for a light targed for the masses. Please do not confuse an OEM manufacturer like Sofirn with someone like Hank Wang (Noctigon/Emisar) who has clearly focused more or less on one UI only for all of his lights and who has a smaller variety of lights for sale. Sofirn's or Wurkkos's largest target group is the "standard customer" who apparently needs a short and concise manual with a foolproof UI. Taking these circumstances into account, I'm even more impressed that they still have two open ears for a considerably smaller target group of us flashoholics/nerds and that they continuously try to fulfill our special wishes, too. I think they would like to combine the best of both worlds to reach every potential customer - who wouldn't?
Personally, I would like to see a stripped version of Andúril with less complexity (no floor/ceiling configuration, no blinky modes, no AUX support, but with simple stepped modes and ramping as well as with a good thermal configuration) that could be adopted more easily in large scale. To be honest, I really like the FC11 UI which IMHO only lacks a manually configurable thermal stepdown.
Very good observation and an even more intriguing question, too. If someone cycles both LEDs to OFF I would consider the light to be in OFF-mode the same way if someone just clicks it to OFF. With mode memory in charge, I would suggest Wurkkos to use the battery status indicator in the switch to light up for 5s (likewise to most of Sofirn's lights that light up the indicator when being turned on) to indicate that the OFF modes are set to both LEDs. But maybe there are more, better ideas how to deal with this?
Ramping UI may be also interesting. Hold - change only output, click+hold - change throw\flood ratio with constant output. (E-zoom:)
Lux-Perpetua, I think Hold - for change output of current Led(or both) , and click+hold for changing throw-flood-both is more convinient. You can save 3 combinations and change it fast. It is similar to Panda 3 UI.
IF25 had tint-ramping and although it may have been coded independent of Anduril had some very similar functions.
Personally I would go with “Hold” for brightness adjustment and “Click+hold” for cycling spot/flood/both emitters. Leaves double-click open for turbo/blinky modes and doesn’t run into the problem with both emitters being set to “Off”.
Having the indicator LED light up (maybe even with a flashing pattern specifically for the scenario?) when both are set to “Off” does seem to be the best solution if the separate output selection UI is used though.
Dual-channel ramping could be cool, but the UI would be similar to the IF25 and I agree completely that you can’t bloat/complicate the UI too much for the market/niche Wurkkos is targeting.
I have discussed the latest approach of HD20's UI with Mark (Wurkkos) today. We came to following conclusion:
I will incorporate the latest input from you guys into the new draft UI. Special thanks to AEDe and BurningPlayd0h for their helpful feedback.
This final draft UI will then be discussed with the manufacturer in the next days.
Ramping mode will still remain on Wurkkos's schedule for HD20 but it might be implemented in a later revision, depending on many factors like market launch schedule, increase in UI complexity etc.. I will try to post an enhanced UI with ramping mode here but I cannot tell for sure if this will be adopted by the manufacturer in revision 1 already or later on in revision 2.
I have urged Wurkkos to put extra care on a good and reliable headstrap/headband to properly support the weight of this light. A magnetic tailcap would surely be a nice add on but it will also increase HD20's weight. So, maybe they can sell a magnetic tailcap individually or put both versions (magnetic/non-magnetic) in the retail box. A big benefit would be a tailcap design that fits to more Sofirn/Wurkkos 21700 lights.
Another update:
Wurkkos is about to decide whether they should sell HD20 with 4.000K for floodlight and 5.000K for spotlight or with both LEDs in 5.000K CCT. I told Mark that 5.000K for both LEDs cannot be wrong. However, when using two different tints in one flashlight the beam should hopefully look nice when both CCTs will be mixed.
From off
1 Click - memory mode
2 Click -> Turbo
3 Click - Strobs modes
Click+Hold - Batt Check.
4 Click+ Hold - lock|unlock
Hold - moon light (memory type of light .) 6 Click+Hold - changing steped/ramping UI
From Strobes mode
1 Click - off
2 Click - Turbo
3 Click - Return to previous mode
Hold - Changing SoS-strob1-strob2…
From Turbo mode
1 Click - off
2 Click - Return to previous mode
Hold - Change in circle Throw turbo - Both turbo - Flood turbo (may be memory ?)
Steped UI
From on
1 Click - off
2 Click - Turbo
Hold - Changing output in circle Low-Med-Hi.
Click+Hold - Changing type of light in circle Flood-Throw-Both. (output is remembered)
Ramping UI
From on
1 Click - off
2 Click - Turbo
Hold - Increasing output then decreasing it.
Click+Hold - Changing ratio throw|flood with constant output.
It would be best to design a tail cap where the magnet can be removed and replaced with a non-magnetic spacer, that way you have a choice.
Maybe the removable magnet could be under a tail cap spring board that is held in place by a thin threaded ring (which uses the same threads as the tail cap) if this could be done without compromising the electrical reliability of the light.
Experienced outdoor people still use maps and compasses during their outdoor adventures.
Any magnet within several feet of a compass will affect the accuracy of the compass reading disastrously. You cannot have a headlamp with a magnetic tail cap anywhere near your compass and also navigate accurately because the magnet changes the compass bearing to the wrong direction.
Let me recommend another LED as 5000K option: Samsung LH351C
This LED has significantly smaller light emitting surface, than LH351D, but it can be driven to very similar maximum power as the Luminus SST-20 (I remember somebody tested it here on BLF above 5A current, so e.g. 3.5A could be perfectly safe).
With this, we could have 5000K 90 CRI under the throwy optic - unfortunately SST-20 high CRI is still not manufactured beyond 4000K, so this would be the solution not to sacrifice throw and keeping it high CRI the same time.
Is Hicri is necessary for throw? I would prefer xpl hi with good tint and efficiency for throw,and good quality light of 351D hicri (ideally nichia E21 of course) for flood.
For me, it is a big plus. I have C8 both with XM-L2 4500K 75 CRI and SST-20 4000K 95 CRI, and the XM-L2 has noticeably “dumber” beam, when it comes to object recognition in low contrast scenes. And I also have the fabulous K1 with SST-20 4000K (which is no longer an option offered by the manufacturer).
However, in some extreme throw designs (above 500kcd), I think, it is less important - then it is mostly about perceived good tint.
I really like your vision of a good UI and I think most of your thoughts have made it into the (hopefully) final draft of HD20's UI. There are only two things I like different:
From Turbo mode: one click ▶ OFF is something I would not like at all. If I used doubleclick to step up from a normal mode to turbo, I would expect a single click to return back to the previous mode and another single click to turn the light OFF again. In a situation when I need full power for a brief moment, I would not want the light to go out with the necessity to start it again. Just my personal thoughts.
Personally, I don't like strobe modes and I would want to them to be hidden in a way they cannot be activated accidentally. It happened to me more than once that I accidentally clicked three times instead of two times and suddenly the annoying flashing, flickering and buzzing began. So, my proposal would be a compromise between convenience and safety (against accidental activation). Strobe modes will still be there but less easier accessible from the turbo mode submenu. Why? Because it is less likely to use another doubleclick when the light is used on full power already than a unintended triple click when using the normal modes. In an emergency situation strobes can still be accessed with enough flexibility by two/three/four doubleclicks in a row. Again, this is just my personal opinion but at least I hope this approach sounds sensible to many others.
So, lo and behold...the UI that I hope Mark can present to Sofirn for their evaluation.
Remark for Mark (Wurkkos): Please regard the green highlighted line items as a possible enhancement for using the ramping mode on HD20. If ramping mode is no option for HD20 right now, please just disregard the green colored line items.
I try to talk to Mark about emitter options a.s.a.p.
SST-20 5.000K 70CRI was probably chosen for reasons of low costs compared to XP-L HI. Another reason could be that Sofirn probably got quite some stock of SST-20 5.000K 70CRI but only few or nothing on stock of good XP-L HI with less than 6.000K. It seems it's difficult for them to get lower CCTs of XP-L HI. Sofirn might be able to test some Osram White Flats in the near future but since it is coldwhite only and difficult to handle (footprint/focusing) I guess we can rule this one out, too. I don't think anyone has ever used LH351C yet but their specs look promising.
Having the upcoming start of production in mind, I guess we need to decide between a coldwhite XP-L HI (probably 6.500K or maybe 5.700K) or a less powerful but smaller SST-20 5.000K 70CRI.
I think for LH351D 5.000K 90CRI we also have few options only.
LH351D 5.000K 70CRI / LH351D 4.000K 70/90CRI - never saw these available or planned in Sofirn's lights but I wish they were open for testing the 70CRIs of LH351D as their efficiency is much better (in return of less color rendition)
XP-L2 (but IMHO they probably have nothing lower than 5.700K) - as efficient as LH351D, beam looks good under a (fitting) TIR lens but awful in a reflector
XP-L HD (but IMHO they probably have nothing lower than 5.700K)
Nichia 219C - bad efficiency and hard to source for Sofirn as I remember from former inquiries
"Activate Moonlight mode" would be more consistent with the rest of the chart if the wording was "Turn ON Moonlight mode".
"Temporary moonlight mode while holding the button pressed" could be more simply stated as "Temporary moonlight mode while pressing button".
"mode memory and changes apply to selected flood/spot/both LED mode" could be more simply stated as "Selected brightness and LED modes are memorized".
EDIT: maybe I misinterpreted what you are saying here. Are you saying that each LED mode can memorize different brightness? Meaning that I could set "spotlight only" brightness to "high", "floodlight only" brightness to "low", and "both LEDs" brightness to "medium"?
If so, then maybe wording should be "Selected brightness for each LED mode and which LED mode was last used are memorized".
"Activate Turbo mode (both LEDs at full power)" would be more consistent with the rest of the chart if the wording was "Turn ON Turbo mode (both LEDs at full power)".
EDIT: your original wording "Activate Turbo mode (both LEDs at full power)" is probably better since the headlamp is already ON ("Turn ON" wording would only be better if headlamp was OFF).
It allows adjustment of how much spot vs flood is wanted, vs having them both locked to the same output when both are on.
This is looking fantastic Lux-Perpetua and everyone else involved. Very excited for this light since I’ve been waiting for a compact spot/flood combo option for a while, and angled format with option for headlamp use is icing on the cake.
My two cents on the emitters is that you can’t go wrong with 5000K for both, it’s the perfect mid-ground. If possible XP-L HI would definitely look much nicer than SST-20 for throw - the 5000K SST-20s I’ve seen have all been extremely green (unless this light is PWM’ed FET only). I’ve heard the same about very green tint for LH351D 70 CRI, but some batches may be better? The problem with that in the throw role is that the 351D simply isn’t very throwy.
Thanks!
1)Yes that may be convenient. But it make ui logic more difficult. 1 Click is off , everywhere , exept turbo.
For example I use hi mode and than go to turbo and than want to turn off. On last step I should press 1click+1click , and I get not turn off but strob
2)Acording you to get strobes fast from off is 4 Clicks.
Also you miss hold from turbo. This is only way to get separate flood or throw turbo.
Another not obvious thing that
to get mid throw+low flood we should set mid throw , than set low flood , than go to both mode. In both mode changes are low+low - med+ med - hi+hi.
Thank your roostre! I have updated the chart i.a.w. your comments. And you were right with your assumption. Each LED mode can memorize different brightness.
Yes, there are some trade offs unfortunately. But turning the light off by one click from turbo would be rather inconsistent with every of Wurkkos's and Sofirn's flashlights. I must confess, I am much more used to using a second, separate click to turn it off from turbo. I am confident that 1 click + 1 click will not be handled as a doubleclick.
Would you often need strobe mode from off? 2x doubleclick is rather convenient IMHO to access strobe quickly enough from off.
Either way, I cannot disagree with you as I also see benefits in your UI vision but Wurkkos (and Sofirn, too) are also a bit concerned about too much complexity. To be honest, I would already be more than happy if they adopted let's say 80% of our common ideas for their UI.
