Thanks hodor!
Well, the led4power driver fitted in without issues, as the original driver also has 17mm diameter (with 2 small flaps that fit the âpillâ, to avoid rotation).
There is no USB charging , because the new driver doesnât have it. The charging port is implemented in the original driver, so when I took it out, it stopped working.
The rubber cover is still there, though (I may need to glue it to prevent eventual water infiltration).
Even without charging, this is a great host to make a DIY pocket thrower with an Osram led (Convoy 18350s tubes fit ).
It may be kind of hard to center it correctly in case you donât have appropriate gaskets. The beam is not 100% perfect due to that, but it throws a lot
In those pics the EagleEye light looks like it has the best focus of all of them. Not sure if that is due to the smaller die and camera settings or if you are just being modest but I cant see anything wrong with it.
Thanks contactr !! :+1:
I guess it has to do with small die led and the bigger reflector (if compared with the S2 and S2+ and the leds they are using). Camera was in auto, if I recall correctly
However, my point is that it is very hard to center the Osram W1 and make a âperfectâ pencil beam .
Below you can see that the âflowerâ shape is not completely uniform, and believe me that this was the best I could do without proper centering gaskets.
I un/screwed the bezel/reflector dozens of times and tried at least 3 different gaskets to make it look well. I ended up âblackeningâ the white gasket to avoid more reflection and artifacts and it also improved a little
After reviewing the Wurkkos TS70, I knew that I really liked it for itâs heft, solid build, and brightness. However, I wasnât really a fan of the UI. Hold-for-off really gets on my nerves.
So⌠brain transplant! I took out the PIC and put in a attiny412 with a tweaked version of RampingIOS / D4V2 UI:
When powered up, the light comes in on turbo instead of the usual double blink then off.
Swapped tactical and lockout modes so that lockout is 4 clicks instead of 6
Added momentary moon and secondary low from lockout (inspired by Anduril)
Oh, and while I had it apart, I gave the XHP70.2 a slice. Overall, I like it much better now!!
Just a simple emitter swap. I dropped a sliced/polished dogfart in a D80v2.
From reading other peopleâs experiences with slicing the LH351D, I expected the CCT to shift a little bit more than it did. I measured 5200K pre-slice and 5000K after. Perhaps I didnât remove enough of the dome.
The tint is very nice with a slightly pinkish hotspot and a little bit of a yellow shift in the corona. I can see some slight artifacts around the hotspot on a white wall but outside itâs not noticeable at all.
Nice work! I have a Olight S1 Titanium that could use a better emitter. I found one video that starts disassembly (removal of bezel) but havenât seen anything after that. Did you follow a site or other video for removal of the pill to access the emitter?
Finally got around to doing an emitter swap on my beloved ReyLight Ti LAN. Iâve gotta say, itâs an interesting MCPCB but one that I hope to never see again.
The process is essentially the same as this video that person you linked also posted, and is pretty much what I followed. I used an old frying pan to remove the old emitter and reflow the new one on however
When I sliced my triple Samsung LH351D 5000K CRI90 LEDs I also was expecting the CCT to be noticeably warmer, but it appeared to remain at around 5000K. I also thought that maybe I couldâve sliced a little more, but any more seemed to be dangerous. I do like the tint overall and the extra throw the slicing gave.
