Update:
Contacted Imalent, they will send a replacement for me once they received my shipment with the moisture soaked unit.
In the meantime, i will use my Lumintop FW21 pro, which is pretty rad.
Update:
How do you unscrew the body from the head? Mine is tight.
uselessuser: Flashaholics:If people who want to solve the problem themselves, just need to take off the body, clean the glue and make it tight”
Just to make sure I can follow: Are we talking about heating up the tube and unscrewing it from the head?
Just cleaning off the glue, it doesn’t work, I still get the red light.
dmstar88: richbuff:Samsung 40T with solder blob powered up the lights, but turbo red light problem with both of my MS03 and all four of the 40T blob top cells. Clean up glue at seal between head and tube and tighten did not solve the problem. Also, I had difficulty getting the extra long Imalent cells to power up the lights, even with tightening both the head and tail by hand as tight as I could. I removed the white plastic that was protruding from the positive button of the Imalent cells with a razor blade, and that solved both problems: the turbo red light problem and the difficulty with getting contact to power the lights were both solved. I can use the solder top cells in my other 21700 lights.
Thanks for sharing this tip… i was pretty upset on the turbo red light issue as well, also the light cant seem to ramp up to level 4 after i use Turbo.
I went out for a night walk and was met with some light rain. Used the MS03 in the rain, Pretty cool until this morning, i saw this:
I contacted Imalent Support, they told me to wait for a few hours to see if the moisture is still showing, if so I have to send it back for repair or replacement.
What a bummer.Update:
Will Imalent cover shipping for you?
How does the FW21 pro compare to the MS03?
[quote=JordanZHP]
No, I am paying shipping on my own as i brought direct from Imalent Lights.
FW21 pro is a pretty fun torch with some cool Blinkies function. The Turbo mode is pretty usable and stable, meaning I can hit on turbo again when it step down and it will still work.
Hope this is helpful…
In what ways? In many ways they are similar, and in many ways they are very different. They are in the same size, power, throw and runtime class. Single 21700, about 9000 lumens. For me, the choice of FW21 Pro or MS03 or NSX53 or TM9K is a matter of personality, that’s why I got all four, even though they are very similar in size, runtime, lumens and throw.
The FW21 Pro is a little less floody than the MS03, with a little more throw.
Yokiamy:I did not experience any problems with my MS03, the only thing is that you’ve gotta be careful where to place it doing current testing. It actually does over 30A and it does get HOT!
Amaretto just posted his comprehensive and valuable review in the German forum. He did not mention the red light turbo phenom.
Thinking about buying the most powerful single-cell flashlight? How about a 13,000 lumens flashlight that burns a hole in your pocket in a matter of seconds? The Imalent MS03 is a beast.
richbuff:I removed the white plastic that was protruding from the positive button of the Imalent cells with a razor blade, and that solved both problems: the turbo red light problem and the difficulty with getting contact to power the lights were both solved. I can use the solder top cells in my other 21700 lights.
I have tried this and I can confirm that it hasn’t worked, I still get a red light and I think you will too if you keep playing with the MS03.
Please remove the battery tube from the head (if unable to unscrew by hand, cushioned tools may be needed, due to the glue) and then check to see if there is any glue or small amount of grey stuff on the annular gold contact where the tube makes contact with the head. It has to be squeaky clean, as well as all contact points. Before re-assembling the tube to the head, grease the threads and grease the inner wall of the head where the o ring needs to travel down as the tube is screwed into the head. Max hand tight is indicated, but just a small amount of additional tool tight may be needed.
Flashaholics: richbuff:I removed the white plastic that was protruding from the positive button of the Imalent cells with a razor blade, and that solved both problems: the turbo red light problem and the difficulty with getting contact to power the lights were both solved. I can use the solder top cells in my other 21700 lights.
Did all that a while ago after IMALENT claimed it was the issue.
richbuff: Yokiamy:I did not experience any problems with my MS03, the only thing is that you’ve gotta be careful where to place it doing current testing. It actually does over 30A and it does get HOT!
Imalent MS03 review | A 13,000 lumens bright flashlight (with 10% discount code) | 1Lumen.com
Like Charles Bridgtec, he gets commission on sales.
I’m finding a lot of “reviewers” are failing to mention universal faults lately.
Yokiamy: richbuff: Yokiamy:I did not experience any problems with my MS03, the only thing is that you’ve gotta be careful where to place it doing current testing. It actually does over 30A and it does get HOT!
I dislike charles bridgtec, he dodges all the questions about problems and it is just a puppet. I will never use one of his affiliate links.
IMALENT were keen to send me a 2nd light after they saw my review:
The 2nd light is also faulty and also makes just a touch over 10,000 lumens like the 1st MS03.
Basically you can use Turbo for a few seconds (Occasionally not once) or if you’re lucky a couple of times then you can’t use it again (or high mode) until you break the tailcap connection.
Looks like this light will sort the good reviewers from the greedy.
Thanks for the update, do you have the FW21 Pro? I was gonna get the MS03 but might get that one instead.
Flashaholics:IMALENT were keen to send me a 2nd light after they saw my review:
I would currently advise against the FW21 pro after seeing a post where someone melted his emitter domes and phosphor off by using turbo.
I’ve not been asked to review a FW21 yet and I don’t personally buy LUMINTOP lights anymore due to poor build quality.
I am due to review the Astrolux EC03 soon which I believe will be brighter than advertised at turn on.
It’s been a long time since I personally had an issue with Astrolux.
Well my ms03 functions as should.
I cam confirm the short turbo time, but mine does over 12000 Lumens, when you calculate an error of 10% this one might do 13k.
If you want it, i am willing to sell it
The Turbo lasts 45 secs as stated and can do it a few times unless it glitches and gives the red light with Turbo/High lockout.
Yours will glitch eventually! Everyone but greedy affiliate reviewers have the issue.
What kind of 21700 battery can i use instead this proprietary imalent 21700 battery on this MS03?
Anything with a stupidly big magnet/solder blob on it. The light is only good for 2200 lumens so take your pick.
Ahh, thanks. Still not decided yet, saw so many pros and cons about this MS03
