Thanks for affirming the amp draw.
Over 1000 lemons after 30 seconds for $5, yeah baby!
The modes are as described, and you can charge with USB, don’t know what the hate is about with some members about this flashlight.
It cost less than a Value meal at McDonalds
The driver looks like pressed in from the front/top and I saw the gap you are talking about at the edge at the base of the bezel, head seems glued good, batt tube gave up after just giving a good grip and reef on it.
Thing seems to heat up nicely, controlled if you will.
No “hate” from me, just learned my lesson with the dreaded AT01. What a POS each of those were… Most 9-LED craplights had better quality than those.
Then again, remember the Tacklife? That was a great investment; wish I would’ve gotten more. Got some diffusion film on it (inside, between reflector and glass), and it’s a kick-arse (now-)floody light that daylights what’s in front of me. Absolutely great all-around-the-house light.
Anyhoo, I’d wait for reviews first before getting burned again on an unknown.
I put a fresh charged yellow 18650 at 4.16v 2 days ago.
I used the light for about 2 mins total on low and I just checked the cell it reads 4.07, that’s not good right?
I measured 38 uA parasitic drain, which is pretty low. So maybe Pete above is correct - that voltage drop is normal for this drain, or yours has a higher drain, or that yellow 18650 is not so good? Maybe you can look at a discharge curve and see how many amps it would take for that voltage drop. Voltage drop is not linear so have to look at 4.16 down to 4.07.
Both NW and CW versions of the Wowtac A2S headlamp are $23.99 (compared to the normal 29.99 price), which was awesome to find since I’ve been eyeing this model for a while now.
Banggood has the Astrolux FT03 SST40-W for 33.99 US right now. If you don’t have one, you need one. Best thrower bang for the buck ever…. Sorry, I missed seeing the word Amazon when I posted this, but I am going to just let it stay because it is a good deal.
I ordered 2 at that price, so when I finally receive them a month or 2 from now, it will be a good day. I am convinced they use very old runners on land, and swimmers in the water. That is the same for all shipments from China though. It is not a service for the impatient. I often even forget about the order by the time it gets here, but the savings on items are just too great at times in spite of the turtle shipping speed. By the way, that Astrolux light can more than match lights that cost 3 times as much. I might even get brave and de-dome one of them.
