I had a similar idea to this 6 month old post from djozz, and his suggestion is the only post that seems to have turned up in my search.
I just wanted to add that if anybody does this, I’m interested as well - thin FRP or flex PCB from Oshpark, or else an MCPCB in a group buy.
Or perhaps Clemence might be interested? The LH351D’s are pretty good, but I’d love to how the lantern looks with Optisolis or E17A’s in there, and perhaps try a slightly different CCT range.
So is the difference between version 4.3 and 5.0 strictly the USB C-C functionality? Or have there been any minor adjustments to the other functionality?
Given the tube diameter, I’m wondering if a beer cozy might fit on this. It would be a way to change at least part of the color for those who don’t want to wait until September to have a different colored body from black.
USB-C PD functionality like you mentioned, and 0 ohm resistors used to activate the 3/4 and 5 regulators as stock instead of having the pads manually bridged from the factory.
I think it was mentioned as a prior suggestion, but some DIP switches would be really nice in place of the solder bridges, even if they can be bridged using some graphite pencil lead.
@DBSAR Been meaning to get in and thank you for producing this thing. Heard you got the Covid-19 and had some difficulties, I’m hoping you’re ok and things are getting better.
Look mate, this lantern is the biz. Much as I love my old paraffin (kerosene) Tilleys and Vapalux lanterns and the old wick storm lanterns for my camping adventures, they are a faff to deal with. I have a big canvas bell tent and recently had a paraffin spill onto the outside canvas when the pole holding the lamp (luckily unlit) fell onto it.
Your lantern, with the warm/cool and Anduril is perfect for my needs. It’s currently sat beside me indoors in preference to the ceiling lights, and as soon as we can get out for a few nights in the campervan it’ll be getting some proper use. Good work fella
Do you know what was the rationale behind the “ohm resistors used to activate the 3/4 and 5 regulators as stock instead of having the pads manually bridged from the factory.” A minor adjustment overall for efficiency, or to address a particular issue? I also agree that dip switches can be a very useful way to customize functionality in a more semi-permanent fashion.
OK, good to know — thanks! Might be possible to utilize a neoprene cover for a water bottle, trimmed to fit.
The biggest reason for this (IMHO) was to remove a manual manufacturing step and related QC needs. The originals required the first pads to me manually soldered at the factory. More than one example made it past QC with incorrectly soldered pads. There’s no knowing how many were sent for rework or how much time was spent on this manual process. Adjusting the traces to accept factory placed 0 ohm resistors lets them be placed automatically and consistently like the other components.
I believe it was due to a quality issue, not getting all of the pads 3/4 and 5 soldered correctly (or consistently). This likely had to be done by hand. By installing a 0 ohm resistor, they can just install the part there (like all the others on the board) and reflow the solder paste and make the connection automatically. That’s my suspicion anyway.
This is probably a strange question, but does anyone know where I could get a few more of the large orange o-rings that come with the LT1? Or even the actual size of the original ones?
I’d like to be able to put one in the groove above the diffuser and another in the groove below it.
Great, thank you for this Bill. While the odds of getting one are probably slim, if you’re unlucky to get one you’re stuck with having to mail it back… which adds significant expense & time. I think I’ll wait for the 5.0 version!
If you have soldering iron (or reportedly an old-school pencil) you can close or open the pads on your own in a few minutes. Having the wrong pads open or closed is a mis-configuration. This runtime vs max brightness adjustment was always intended to be a user-serviceable item.
I to prefer the lower termination voltage of charging, (better for the cells) the variation between lanterns is likely due to if your using different typs of cells in different lanterns i found, and variations in the TP5100 charging chip programming.
Mine shuts down at 2.65v.
I had to use a single crappy cell to test that.
Using the 4 Sofirn cells, the darn thing shines forever!
Also mine is the Rev 5 version. I got only about 1.5a max charge using the included cable.
The power supply I used is capable of more. It’s a QC 3.0 (supposedly).
Don’t care really, it’s a wonderful lamp.
If I need faster charging the Vapecell S4+ gets thing done quickly.
Just curious what you are getting.
The charge circuit only supports basic charge currents. One of the design criteria was to be chargeable from low current sources like a small solar panel. A high current fast-charge was not pursued for various reasons, including maximizing cell lifespan with slow charging.
