Test/review of Xtar INR18650 2600mAh (Cyan) 2020
6 posts / 0 new
HKJ
HKJ's picture
Last seen: 22 hours 17 min ago
DSC_2971
Official specifications:
  • Nominal capacity: 2600mAh
  • Nominal voltage: 3.6V
  • End of discharge voltage: 2.5V
  • Max. pulse discharge current: 35A
  • Max. continuous discharge current: 25A
  • Charging temperature range: 0°C ~ 60°C
  • Discharging temperature range: -40°C ~60°C
  • Cycle life: 500 cycles
  • Internal resistance
Xtar%20INR18650%202600mAh%20(Cyan)%202020-info
This is high current cells with fairly low capacity.
DSC_2970
DSC_2972 DSC_2983
DSC_2973
DSC_2974
DSC_2975
Xtar%20INR18650%202600mAh%20(Cyan)%202020-Capacity
The two cells do not match, the A cell has lower capacity and handles less current. I stop the test a bit early at high current due to the cell temperature.
Xtar%20INR18650%202600mAh%20(Cyan)%202020-Temp-10.0
Xtar%20INR18650%202600mAh%20(Cyan)%202020-Temp-15.0
Xtar%20INR18650%202600mAh%20(Cyan)%202020-Temp-20.0
Xtar%20INR18650%202600mAh%20(Cyan)%202020-Temp-30.0
Xtar%20INR18650%202600mAh%20(Cyan)%202020-CapacityTimeHours
Xtar%20INR18650%202600mAh%20(Cyan)%202020-Energy
Xtar%20INR18650%202600mAh%20(Cyan)%202020-PowerLoadTime
Xtar%20INR18650%202600mAh%20(Cyan)%202020-TripCurrent
Xtar%20INR18650%202600mAh%20(Cyan)%202020-Charge
With these charge curves it looks like one of the cells are faulty.
Xtar%20INR18650%202600mAh%20%28Cyan%29%202020-pulse-1.0%2010%2010-IR
Conclusion
One of the cells looks fairly good, the other do not.
This makes these cells a bad choice.
Notes and links
The batteries was supplied by Xtar for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
BT100
Last seen: 1 month 1 week ago
Thanks for the review !
Superstocker
Superstocker's picture
Last seen: 1 day 3 hours ago
Thanks for keeping us informed HKJ!
Blggg
Last seen: 1 month 4 days ago
Thanks for the review. I’m surprised by how inconsistent the 2 batteries are.
d_t_a
Last seen: 4 hours 45 min ago
Maybe need to inform and ask Xtar the reason for 2 Xtar 2600mAh 18650 batteries that behave somewhat differently, might indicate the internal battery used is different?
Ventsi
Last seen: 20 hours 29 min ago
Thanks for another review, HKJ!
Surprised by the low quality batteries by Xtar, I thought they only use reliable sources for cells.
