Haha, I have done all the things that you have done too NeutralFan, including fiddling with resistors for finetuning the balances.
To challenge your “no more after this”, on aliexpress, with some searching, you will find 0603 leds of several tints aqua and cyan (I have 480nm, 490nm, 500nm) that are genuine single colour leds (not phosfor- converted) and are fairly efficient so suitable for lighted tails. Also a phosfor-converted aqua can be found (blue led mixed with some green emitting phosfor) that is really efficient.
I think I’m beating my head into a wall on this, but is there a simple way to get the lighted tailcap visible through the metal S2+ switches? I’m trying to get lights behind a purple host.
Ideally it’d be quite dim, even in pitch black - it’s for my daughter’s bedside table, just so she has a point of reference to grab it. I do want to change the colours though, so I realise there’s probably different resistances needed.
I got some of the lit tailcap boards from Convoy, but they’re nigh-on-invisible through the cap. I tried removing the resistors and just joining the path, and they flash bright momentarily, then go back to exactly the same brightness they were with the resistors on.
If it gets too hard I’m happy to buy something else, but l4p is down, and I (to be honest) haven’t yet checked if Lexel is still doing them.
I would think adding a bleed resistor would allow the leds to get what ever current the bleed resistor would allow. I seen several post talking about the plastic ring around the metal switch being black and wouldn’t let light through. I’m assuming you have a metal switch that’s made to light up with the clear washer and all.
Yep, the rubber around the metal is clear, it lets light through:
And the kit came with a clear washer. Interesting, I would have thought that with no resistor, they’d be brighter given that it’s direct voltage? But an interesting read nonetheless.
If I move the tail pcb over to another light with the Convoy 5A CC driver, it does the exact same, so it’s like the actual LEDs are restricted to this amount of brightness inherently.
It’s a matter of just how much current the driver will allow from the positive of the battery to run through it and back down the tube to the switch. The current is running in reverse of normal operation. Thats why a bleed resistor is needed in some lights and some need it for the firmware to behave properly.
I know your going to need more current with the metal switch to get light through than a clear rubber boot switch. For my clear boot lighted tailcap switches I usually use 120k resistors at the leds. Its hardly visible in daylight but at night on my bedside table its easily found. If its too bright (resistor value to low) it looks like a night light shinning on the ceiling and the wife complains . 120k and above works good for me and last 1 1/2 years or more with the parasitic drain. If you get the parasitic drain to high the battery could be drained in weeks to a few months.
I guess my issue is that it isn’t anywhere near bright enough - I’ve removed resistance from the switch board, and it’s on a CC driver. Might find a bunch of replacement LEDs and then swap them out, see what goes brightest (although I thought blue was usually pretty bright).
Green LEDs are the most efficient by far and will be much more brighter than blue. For my tailcaps, green uses 0.03 milliamps vs blue at 0.21 for the same comparative brightness.
So if you’re having problems seeing light thru the S2+ metal switch, you may want to swap the LEDs to green. Unless you don’t mind lowering the resistance and putting more amps into blue. Any color will eventually work if you lower the resistance enough, but I prefer to get a year or more out of my lighted tailcaps before I need to recharge the battery.
I have a Rev3, I put a 560 ohms resistor, and in my tail cap switch, I changed the resistor to 2.7k ohms, and finally, it works all modes well. The only thing I experienced is when I try to use the 1k ohms has a problem, based on my case, using from 2k ohms above will work fine on the tail cap.
All of the said resistors, I took to my electronic device which is not working at all, ( tv receiver).
Hoping that this experience might give an additional idea to others.
Usually a certain bleeder resistor value is needed for a driver to work and the switch resistors just impact the brightness/current. But strange things can happen with various drivers and firmware.
Did you try a different bleeder resistor when you used the 1K ohms switch resistors? If the brightness is good enough with 2.7K, then no worries.
Using 1K Ohms is a little bit lighter but noticeable. I did not try yet to changed the value of the bleeder. As of now, i am planning to add 0805 Led and a resistor as well on tail switch, to mix colors. That might be the time to changed the value of the resistor if that will not work.
At first, I only wish to work all fine after this modified, but now I am seeking more to make this project more impressive.
I finally have a true yellow tailcap that is efficient! It measures 0.15 mA - so with a 30Q battery, it will last over 2 years. I would consider it a bright (canary) yellow.
I combined warm white and green 0805 LEDs:
Here it is compared to my green and warm white tailcaps:
Can someone please help me to get the tailcaps working right?
I have an orange and a blue one,
and I have 2 Convoy S2s with the same driver
The blue one works on both, but the orange one is messing with modes of both and puts the drivers into the low battery flashing mode when I try switching modes by pressing the switch
I have checked the LED resistors, both are 300ohm
Should I put a lower value resistor for the blue?
[Edit] It shouldn’t be a bleeder resistor problem since the flashlights work with one, right?
