Thanks, I'll try to get new code.
You can use BGCONV now.
Can I get coupon for JETBeam RRT01 Raptor please.
RRT01 Raptor code please.
2020/06/19
2020/06/20
All coupons for flashlights in the first post of this topic ➔ LINK
All coupons for batteries, chargers and others in the second post of this topic ➔ LINK
Sorry, was a bit busy, did beamshot video and still photos but wasn't able to post about them.
some still photos:
left side is Convoy C8+ XPL-Hi 3A (5000k, 7135x8 Biscotti) at max, right side is Wainlight C8+ Osram NM1 (2.8Amps High)
I'm using an entry-level camera, so pictures may not be exactly great. But I manually adjust the camera settings (not sure if they're accurate) to these settings:
white balance: set to "daylight" setting / ISO:800 / aperture: f/2.8
I used 3 different shutter speed settings to take the same photo.
a) shutter speed: 1/10th second
b) shutter speed: 1/100th second
c) shutter speed: 1/1000th second
beamshot video (distance to wall ~ 18 meters or 60 feet)
beamshot at farther distance (opposite building ~120-150 meters or ~400+ feet from flashlight)
Convoy C8+ (XPL-Hi 3A) beamshot:
and the beamshot for the Wainlight C8+ Osram NM1
A jet beam m1x is not $209. Why is that?
Thank you!!!!!ー!
FW3A brass code please.
Hi everyone. what is the best coupon currently and is there anything at imalenta ms18 or r90ts, thanks in advance for your help.
Interested in RRT01 and 03, send Code Please, Thank you ! Lg LitN
May I please have the Haikelite HK04 xhp50.2 coupon; would like to order ASAP.
Thank you.
