I finished off the modifications of my Q8. It’s now very much one of a kind. I had previously:
- Stripped the anodisation
- Flashed it with Anduril
- Bypassed the springs
- Swapped the glass for AR
- Fitted brass screws
Changed the switch LEDs from green to warm white
And today, for the pièce de résistance, my Q8 MCPCB with 4 x 3V XHP50.2s arrived from Sofirn (a custom order which they were happy to oblige).
It’s an absolute weapon now. In my Maukka-calibrated lumen sphere it went from 6,400 lumens with the old XP-L HDs to 16,600 lumens with the XHP50.2s. That’s just over a 10,000 lumen increase! Not bad for $20
Now to wait for it to get dark so I can take it for a proper test drive.
Sandpaper 600>1000>5000
This is my first thrower, so I have no comparison, but I’m (still) impressed. Shines much better than C8 with xpl hi, due to easier led centering. See the Lexel thread on this scalping method.
I did the same swap on my S1R II a while back and I was really surprised at how nice the tint is on the 3000K 90CRI XM-L2. It’s the second-pinkest LED I’ve seen after the sw45k.
I put the same emitter in a C8+ and while the tint is still very nice, it isn’t quite as pretty as it is in the S1R II. Must be how the beam is being blended by the TIR.
After trying one of Sofirns LH351D in 5000K, I finally gave my Klarus Mi1C a LED that has less green than the 219C and makes a slightly larger spot. Wanted this for a long time and now decided for the right LED.
That’s impressive! Mine doesn’t appear to have any magenta tint to the beam, but I’m very okay with that regardless as it’s not horribly green or even yellowish, just a nice, warm white light.
I filed down and fit in a 3535 MCPCB into a black S1R II a while back, using a sliced 5000k dogfart and that one is also extremely nice. Again not a rosy tint but extremely pleasant to use with this TIR.
Also took a couple comparison image of the 3000k XM-L2, Sliced 5000k LH351D, and stock 6500k XM-L2. Used the tungsten WB setting on my phone so the beams look a little cooler than IRL, but it’s still a huge noticeable improvement.
Absolutely!
If only Olight used press-fit bezels that were easy to access on their other models like the S1R II and S-Mini
Yesterday I bought a cheap AA zoomie flashlight on a street store.
At first I thought it was like those AA zoomie lights we can find all over the place on AliExpress. Something like that Warsun penlight zoomie .
But then I noticed it wasn’t.
This is a push-pull, not twisty zoomie (that I like), but…when I started opening it, guess what?
It is all press fit and the pill is plastic, no shelf! :o
The driver is single mode, the led is CW! So I started thinking about a mod. And so I did!
Mod:
XML2 T6 3B on aluminium PCB (filed to fit the pill) + Lumintop Tool AA V2.0 driver + silicone inside between the PCB and the driver
As the driver doesn’t have metal parts on the side to make contact with the host (as it is press fit) I added some wires to make that contact! Otherwise it wouldn’t work.
The silicone was to, somehow, help to disspate someheat from the PCB. It will not be super effective but it is probably better than having nothing
And this is the flashlight (zoomed in), compared with the Tool AA and the Livarnolux TL273:
