I use electronic lockout all the time when I’m pocket carrying an eswitch light. All my eswitch lights are Andruil so it’s easier for me to do 4 clicks with one hand than to twist the tailcap. I also have momentary when electronically locked out where a mechanically locked out light has to be “unlocked” to get any light.
Definitely not with batch #1 but I will suggest to offer more colors with next batches. Sofirn is about to launch their LT1 with great new colors, so I see a lot of potential here to offer these colors for their entire product range and even for third party brands like Wurkkos.
That would be cool. I really love my colored lights and I’m beginning my purge of boring black lights. No doubt that some black ones will make the cut but I will likely de-ano them since I dig that look.
Mine just showed up yesterday. Will be doing a review soon. Initial impressions are great. Sure, I’d love if it ran Anduril, NarsilM, or RampingIOS… but short of that, it’s been good so far. Bright, compact, USB-C charging, ramping option with single click on/off, etc.
… and after my review is done, I’ll crack this thing open and see what chip it’s running and if I can give it a brain transplant
I just placed my order for one. Hopefully, you can successfully upgrade it to Andruil. My SP36 BLF is my only Andruil light with LH351D and I love it!
there is a bug in ui: if turbo or strobe is accessed directly from off, long press activates last used mode. From that state, flashlight cannot be turned off and mode cannot be changed. Only action is double/tripple click to go back to turbo/strobe and then flashlight can be turned off,
there is a PWM detectable by phone camera (similar speed to bistro firmware),
high (~1.7A tailcap current) step down is after 5 minutes to 60% of initial high mode, which is almost equal to medium mode,
turbo (~3.9A tailcap current) step down is after 1 minute, lasts 30 seconds, so after 1:30 flashlight is on 20% of initial turbo mode, which is almost equal to medium mode,
standby: 1.41 mA initially, 0.03 mA (= 43 μA measured on different scale on my DMM) after few seconds,
eco: 7.67 mA
glass is not AR coated,
during charging flashlight can be turned on in low mode,
with charging cable connected flashlight can be turned on in low mode even without battery,
magnet is strong, flashlight can be attached to round pipe in horizontal position without an issue,
magnet in the tail is probably not glued and small rattle can be heard when flashlight is detached from a surface,
[...] there is a bug in ui: if turbo or strobe is accessed directly from off, long press activates last used mode. From that state, flashlight cannot be turned off and mode cannot be changed. Only action is double/tripple click to go back to turbo/strobe and then flashlight can be turned off [...]
Thanks a lot for posting your observations, g_damian. I will let Wurkkos know about this UI issue, so they become aware of it. Hopefully, this will be rectified in revison 3.0 of FC11 (with type C-C cable support). I also noticed rough edges on cooling fins and tailcap chamfers on my prototype sample and suggested Sofirn (manufacturer) to improve the manufacturing process. However, it seems there's little margin left to do some extra post-treatment to those things as FC11's price needs to be kept very low. The same will probably apply to the missing anti-reflection coating on the glass lens.
I want to add that the UI is changed now. There is hold from off for moonlight, and no more long press to turn off. The bug g_damian mentioned exists but seems like it doesn’t effect normal use too much.
I swapped a 3500k LH351D into mine, I’d suggest those who like warmer LEDs try it. The stock 5000k LH351D had enough green tint to bother me, I have some of the “dogfart” LH351Ds that seem less green.
Just my .02
“press and hold for 0.5 second to turn off”
That killed it for me
Update: Manuals available for download in English and German language, see post #2.
The press and hold to turn off is only in the stepped mode. In ramping mode it is the normal click on – click off.
Yes. E.g., Folomov C2 needs three clicks from off. That’s a one-handed, fast operation. I guess four clicks are ok, too ;-).
Smile, you cannot kill them all.
Light looks cool. Will any colors or clear ano be available on these?
I’m interested in this one, looks promising with the 5000K 90CRI emitter.
Current lights:
Emisar D4V2 SST-20 4000K, D4V2 Ti SST-20 2700K, D4V2 Ti SST-20 4000K, D4V2 Ti XPL-Hi V3 1A, D4SV2 SST-20 3000K | Noctigon KR1 OSRAM W2, K9.3 XPL-Hi V3 3A + SST-20 2700K | Fireflies PL47G2 XPL HI V3 3A, PL47G2 SST-20 4000K, E07 219B 4500K | Lumintop FW1A SST-20 4000K, Tool AA 2.0 | Nitecore LR12 XP-L HD V6 6500K, TUP XP-L HD V6 6500K | Sofirn C01S SST-20 4000K, SP10S LH351D 5000K, IF25/LT1-M SST-20 2700K + 6500K w/3D printed diffuser, BLF SP36 LH351D 5000K, BLF LT1 | ZebraLight SC700d XHP 70.2 5000K Hi-CRI, SC53Fc XP-L2 4000K | Convoy C8+ SST-40 6500K | Acebeam H30 XHP 70.2 5000K | Manker E14 III LH351D 6500K
The pocket clip should be black and deep pocket carry clip. Silver just doesn’t look nice,
Better to hv it and not need it than to need it and not hv it.
If I recall correctly, the final product will have a black clip.
It’s been a couple weeks, any news?
Not yet. The prototype sample Wurkkos sent to me is still kept at German customs.
The first batch of FC11 will come with the UI stated in the OP, later batches may get some improvements.
link?
Old Lumens Contest 2020 - Hand-made light category
ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20 | Baton S1
Boruit D10 w/ Quadrupel Fet+1/Anduril | EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Olight S15 Ti | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special | Thrunite T10Tv2
Supfire M6 3xXHP50.2, Sofirn C8F, Unfinished: Sofirn SP70, IYP07/Tool AAA hot-rods, Jetbeam E3S
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
Link
Abby Normal?
Are you saying that you put an abnormal brain in a 7 foot tall, 54 inch wide GORILLA!!!???
How to Post Images on BLF // Many knives for sale (USA only)
How to move a thread
I hate you guys…
I just ordered one now, too.
No brain transplant yet, but my review is up:
http://budgetlightforum.com/node/70663
hello.
i made a video of this flashlight
www.youtube.com/bronzborz
Yet another light I don’t need ordered
It really is a nice light. It’s just one of those good all-arounders. If only it didn’t have that timed step down.
I’ve got the SC31B torn down and working on new firmware. The FC11 is up next.
Add a 1/8 minus-green for those lower levels and this thing shines!
Timed step down is only in Turbo mode, what about high (700lm)?
I just received mine.
Overall pretty nice piece of lumens
Nice summary
I actually added 1/8 minus-green to mine and it feels perfect…at the expense of some throw, of course.
