On the FW3A driver the inner ring connects to the switch sleeve and the outer ring connects to ground.
In the FW3E they must’ve reversed that. The outer ring connects to the switch, while the inner ring connects to ground. It works without the sleeve, because both positive and negative battery terminals are on the top of the cell. The circuit through the body tube to the tailcap is not used for main power at all… it just carries the switch connection.
Pretty simple solution. And this light could be good for people who don’t have a charger or don’t want a fiddly sleeve.
That said, it’s not for me. I prefer being able to swap cells in my light unless there is no other option.
Interesting, though not novel. For example, Olight uses this setup with proprietary cells where positive and negative contacts are both on the top of the cell and a single negative contact at the tail facilitates charging as well as signaling for the tail switch.
Yep, the newer 21700 models use this design. Warrior X Pro has a two-stage tail e-switch and M2R Pro uses the same tail switch in addition to the e-switch on the head.
There are some older models that also use a tail e-switch but have the tube-in-body design.
I am not sure if this has been answered anywhere but my FW3A is going berserk. After lending it.
I can’t configure or reset anything. I sort of recognize that while ON and holding the e-switch it is doing step ramping but that’s about it.
I can’t find any hint how to reset the settings to default.
If it’s an older model it won’t have a reset. Just change one thing at a time. Is it in muggle mode? Get out of that. Then change to smooth ramping. After that you might need to reset your ramp levels.
If you have a newer model which does have reset, loosen head to cut power. Hold down button while tightening head and keep it pressed. I think it should blink or something to tell you it’s reset.
I can’t figure out if it’s an older model. I got it a year ago. The loosening head reset didn;t seem to work. Tom E posted recently that there is no way for you to figure out what version of Anduril you have on you flashlight. Maybe I will make a suggestion.
Interesting. Before production, we tried to get Lumintop to fix the inner sleeve issue… by improving manufacturing tolerances enough to match what Fritz made. Getting all the right parts consistently in the right place is generally sufficient to fix the issues. However, they were unable to do that, so it ended up being common to have things out of alignment or even have a driver shelf which wasn’t big enough for the driver.
So I guess this was one way to solve it. The proprietary cell is a deal-breaker though. Also, the clip wasn’t adjusted to fit the new length… and if there’s no inner tube, the entire light’s diameter could be reduced.
In any case, would be nice if they’d update the firmware. From zeroair’s review, it looks like it’s running a pretty old version.
It probably doesn’t have a factory reset function… but if it does, it would be accessed by a “13H” action. In other words, click the button 13 times, but hold the last one for a few seconds.
But it probably doesn’t have that, because the factory reset function was added a month or two after the FW3A was launched, and Lumintop rejected the firmware updates I sent.
The 13 clicks thing is unique for the FW lights, right? The “hold the button while connecting power” is for more conventional e-switch lights, right? I’m always getting these mixed up. Lol
The 13H thing is currently only used on lights with tail e-switches… because on those, it’s usually impossible to hold the button while connecting power. For the FW3A in particular, power is connected long before the button.
I’ve been thinking of adding 13H as a standard thing on all lights though, for consistency.
