Ordered the V3 kit yesterday off of Amazon on the Sofirn discount, received it this morning. Really like the UI.
Only issues I see is ramping is too slow, and in mode levels, the levels are too few. Moon should be included in the cycle, maybe 1 more. I don't see any issue with 5 levels when they switch that quick.
Wish the 5000K was available on Amazon. The 6500K has the classic blue spill, white center, and yellowish corona.
Also wish they'd blink out the voltage level with that blue switch LED on power up - have it do something useful.
The original "v2" appears to be discontinued though, it uses the XHP50.2 6-volt LED and a boost driver, this model is stated as having "2500" lumens.
The updated "v2" still looks similar physically, but it now uses XHP50.2 3-volt LED and appears to use a similar driver as the SP33v3.0, except a bit lower lumens, this model is now listed as "3000" lumens -- it's basically just a slightly lower SP33v3.0.
beamshots comparing the original SP33v2 "2500" lumens with the updated SP33v2 "3000" lumens and also an SP33v3.0 "3500" lumens
(unfortunately not exactly apple-to-apple comparison since the SP33v2 '3000" lumens I got was 5000k tint while the others are 'cool-white' tint.
I have a couple old SP33's that have the 6V XHP50.2, but unmarked version. Think your V2's were unmarked. Was wondering if mine were V1 or V2. Maybe V1 was an entirely different LED?
Btw, the 3500 lumens rating is pretty honest. Use a 30T or 40T and you get a little better. Bypasses on the springs would probably do even better.
I have one of the 3000 lumen v2 sp33s. I can believe the turbo is 3000 lumens, or close to it. What I find strange are the lower settings. Moonlight was stated as 5 lumens in the manual but it is closer to 0.5 lumens. The low, mid, and high modes, which were supposed to be 150, 400, and 1000, respectively, are more like 80 and 250 and 800. It’s not that noticeable of a difference on high compared to other lights claiming 1000 lumens (Fenix UC30 and PD35). But those lower modes definitely are dimmer than other counterparts stating those numbers. Not that that’s a terrible thing, it just seems odd to have actual output on the lower modes be overstated.
The original SP33 v1 "2500" lumens (XHP50.2 6volt LED) will have a tailcap current of 6 Amps on Turbo, no higher. <= this will be a good identifier for the older SP33.
The SP33 v2 (XHP50.2 "3000" lumens) will have around 8-10 Amps on Turbo (tail current from what I remember, will find my notes...)
The SP33 v3 (XHP50.2 "3500" lumens) will have higher than 10 Amps (probably 12-13+) tailcap current on Turbo, based on my measurements with a fully-charged 26650 battery (UT210E clamp meter) (tail current from what I remember, will find my notes)
Also, using the Zak.Wilson's "CeilingBounce" app and measuring the "ceiling bounce" (sorry I don't have a light integrating device as this time), gives the following graphs, which show different thermal control.
Ah, ok. They were all XHP50.2's. Thanx! I had been planning to swap in 3 channel drivers that CK designed here: https://budgetlightforum.com/t/-/55051, but never got around to it.
I believe these boards will work on all SP33 models, appears nothing changed in the basic driver layout, though not sure, haven't confirmed.
Interesting fyi, I added 22 AWG wire bypasses on the springs (short ones in the center of the spring), and got ~ 25% boost in lumens and candela.
Measuring amps at the tail, on a charged up 40T the amps went up from 14.7A to 16.5A, but that's only seeing the bump of the bypass on the driver side because my amp measurements are with the tailcap off. I did the before/after tests with both a 40T cell and a red Dolidada 5500 26650 and saw about the same percent bump. These springs are not high performance, accept maybe for their thickness but they are not low resistance.
We've been get'n spoiled on the high qual springs and double springs in our lights as of late - these are standard springs. I'd be worried about melting them with a good cell without bypasses.
Confirmed - went from 2200 lm in kit spec (kit 26650 and everything out of the box) to 2820 lm with bypass (2x 22awg twisted ends, soldered to spring).
