Interested in the 2mm Osram and hopefully the Boost HX. But interest depends on how good the driver is because the Noctigon K1 already has a quality regulated driver. Hopefully send the light to someone that can test this light properly before selling. I got a refund for the SBT90.2 version because of how Astrolux messed up so many things on that version.
Interested
Interessado
Well this depends on the driver. The 2mm size LED you can direct drive so the stock driver will be fine but the smaller 1mm LED needs to be amperage limited. Do they have a driver in mind? I think you can get these LEDs in 5000k tint also.
Interested
I suspect they are having the same problems with the reflector improperly focusing the beam pattern as they have with the SBT90.2 version.
You’d figure this would’ve been well tested at the prototype stage, unless this is something to do with manufacturing tolerances. Ironically enough, I see an add for Astrolux FT03S at the top of the screen… with SBT90.2. :person_facepalming: Problem hasn’t been addressed with fixed stock available to ship yet, right?
FT03 with Osram LED, interested. But hopefully the reflector size/depth are tested properly to get max candela (in other wods, properly focused to get the most out of it).
Interested
Interested
Did they force you to ship it back to them in China at your own expense?
Project is gaining traction.
Interested
Any hope of adding aux led’s or anduril? ala ft03 mini
We are not going to change the design other than providing a OSRAM NM.1 option. Maybe gen 2 for 2021?
I’m interested if FT03 becomes available with Anduril and CSLNM1.TG or CSLPM1.TG. AUX LEDs would be a nice bonus I think this light would need a regulated driver; 5A for NM1 and 7.5A for PM1.
This flashlight could be the “Noctigon K1 killer”, because Astrolux is so inexpensive.
Interested
With the Osram! Interested
Interested.
Interested
Interested depending on price. Curious if this light is still happening. 8 months with no major updates.
