You guys would probably like my version of Anduril then. I got rid of the blinkies on the 3 click menu - all it does it voltage readout, temp read out, and version num blink I up'ed the max temp to 90C as well.
I would like that along with a method to simply load a user interface customized to my preferences through a USB-C charging port that also functions as a data port.
No clue what’s on it. It’s currently on the list of license violations since they’re distributing the product without providing source code.
However, I just recently got a bit of info about it, suggesting that the OEM might be Sofirn… so hopefully I can contact them to get it resolved.
And in general, I think there needs to be a map to help people figure out what firmware ships on commercial lights. Will probably put up something about that soon, since it’s a common type of question.
im positive the ec01 is made by sofirn, the switch feels identical to my c8f… weird they would be violating your license like that, they should know better.
Not that weird - I’m pretty convinced Sofirn are using at least parts of TK’s code in the Wurkkos FC11 and others that have non-Anduril implementation of stepless ramping. The operation just seems too similar to the full Anduril operation for it to have been developed as fully independent code…
Only TK would be able to find out and reverse-engineer the driver to know for sure, but even using snippets of code should require the license terms to be met.
Are you claiming that because the UI is similar, parts of the Anduril code must have been used? Do you have evidence beyond superficial similarity? Stepless ramping UIs had been independently developed and used in flashlights for years before Anduril (or its predecessor Narsil) were created. It’s more likely that Sofirn’s ramping UI as used in the Wurkkos FC11 and SP36S was developed from their own ramping UI as used first in the Thorfire TK18.
Anyone? I’m looking for some “bigger” MCU then Attiny85 supported by Anduril.
I tried to look through the FW repository, but there is so much versions and the orientation isn’t easy…
BTW files in this repository gives me “404” error: https://bazaar.launchpad.net/~toykeeper/flashlight-firmware/fsm/files/481/ToyKeeper/spaghetti-monster
EDIT: After some try I was able to get the FW as tar. After digging in the hwdef files I found Attiny 1634.
So far, just the attiny25/45/85 and attiny1634. I started adding attiny841 support too, but that project got cancelled. There’s also some very recent tinyAVR 1-series support too, added by gchart, but I haven’t merged it in yet.
I always liked the bike flasher but with Anduril for which you can adjust its brightness, at max brightness for example, the effect is less noticeable than at medium brightness, so instead of using the bike flasher, I’m using the tactical strobe at its lowest speed but I find it too fast (I’m using a FW3A with a red filter as a rear light).
Would it be possible to have a speed for the tactical strobe down to 1 flash/sec and an adjustment to the effect of the bike flasher along the ramping brightness, please ?
The bike algorithm is very simple… it runs at level N, and the pulses run at level 2*N. So, if it’s set to level 40/150, the pulses flash at level 80/150. However, it doesn’t limit the brightness to halfway up the ramp. It doesn’t stop at 75/150. The default allows it to go up to 120/150.
So it should then pulse at level 240, but there is no such thing. The light itself can only go up to 150.
In other words, no, I can’t make it brighter to make the effect more noticeable. It’s already going as bright as it physically can. If you want the pulses to be more visible, you’ll instead need to turn the brightness down. Like, instead of running at 120/150, maybe try turning it down to 90/150. Either way, it’ll pulse at 150/150, but that will look more noticeable when the base level is lower.
That … may be a bit excessive. Tail lights are usually not thousands of lumens. It’s likely to anger people behind you.
Have you considered using beacon instead? It has adjustable brightness and can run at 1 Hz…
Just bought sofirn sp36 anduril version and i’d like to use strobe cycles as momentary. Tried to power off while in strobe and 5C power on. Not working, did i miss something? Or maybe this light use an older anduril version? Any way to upgrade it to a newer firmware? Thanks for any input…
